Old 06-21-2013, 06:28 PM   #1
ThrasherJP1984
ThrasherJP1984's Avatar
Drives: 2011 CGM V6 Camaro
Need help with Door and Dash inserts!!
Does anybody know what kind of paint remover will work to get the paint off the inside of the factory door inserts without damaging the plastic???
ThrasherJP1984 is offline   Reply With Quote
Old 06-21-2013, 06:35 PM   #2
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
you can damage them....if you are not experienced at this thing. Polycarbonate is tricky stuff and I have seen people damage MC helmets by using the wrong remover.
Glen e is online now   Reply With Quote
Old 06-21-2013, 06:40 PM   #3
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Graffiti remover is pretty safe. That's what I sanction in my DIY thread. However, even with that there is still a potential to damage the plastic. That stuff is polycarbonate, so it's pretty sensitive.
Sanding is your safest bet - takes longer (a lot longer) but you'll have peace of mind knowing you're not damaging the plastic.
nUcLeArEnVoY is offline   Reply With Quote
Old 06-21-2013, 06:45 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by Glen e View Post
you will damage them....
Not true. There is a very well written DIY write up in the Guide to Camaro5 DIYs sticky
Click to view my build thread
Old 06-21-2013, 06:59 PM   #5
nUcLeArEnVoY
Thanks, Stig!
Old 06-21-2013, 06:59 PM   #6
Glen e
Glen e's Avatar
its a great DIY.... but like the author of the DIY says above, polycarb is tricky stuff - I would take them off and let a body shop spray them...JUST MY OPINION...have mod my response above as we are on the same page
Old 06-21-2013, 07:02 PM   #7
nUcLeArEnVoY
Your suggestion definitely holds water for someone who is unsure. No matter what situation, the paint needs to be stripped off which is where the potential for damage lies. Hopefully a body shop will be able to do that more safely than a DIYer would.
All in all, sanding is the only way you won't irreparably damage the plastic, so you have to determine what's more important to you. The quick, easy and potentially risky way or the slow, difficult and certainly safe way.
Old 06-21-2013, 11:35 PM   #8
ThrasherJP1984
so for the sanding of the parts what grit did you use and what did you do after sanding? Like did you have to make it shiny or does wet sanding take care of it?
