HeadlightArmor
Old 07-02-2009, 02:40 PM   #57
Rockytophummer
Rockytophummer's Avatar
Drives: 2006 Hummer H2 2010 2SS Camaro
Originally Posted by irpq11 View Post
Interesting. Last night I did a timed run on the road leading home from the office. (or I guess I should say this morning) using the Dynolicious on my iPhone. Calibrated, mounted tight, and ran. I know it's not the most accurate instrument but I'm told it's fairly close.
That being said, I don't know what to think of this run. I only went to like 85 or 86 MPH before I backed off so it wasn't a quarter mile. I set the vehicle weight about 200 lbs too light because I didn't account for me in the car and I only put 3800 lbs. and I know it's a little more than that. So anyway had I added the correct weight, the horse power would read a little higher.
Straight, flat road. 3:30 in the morning so nice and cool (for Bama) and I reved to about 2000 rpm before letting off the break and getting on the gas.
Anyway, check it out. I can't wait to try it again.
Attachment 35918Attachment 35919Attachment 35920
Which App is that? Seemed like pretty good numbers. Your not happy with that?
Rockytophummer is offline   Reply With Quote
Old 07-02-2009, 02:42 PM   #58
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Verio View Post
This sounds like new ground to me... however, I've read reports on this site where their cars seemed slow because they were breaking it in easy... but after they got on it, it came alive very quickly.
Then again, the folks who beat on their car out the door of the dealership have always run fast.
Maybe that's the key. Maybe the computer sets a threshhonld and you just have to 'raise the ber' so to speak.
Originally Posted by rayhawk View Post
I definitely wouldn't trust the hp readings, but if the time to 60 is even close, you can go ahead and take that winner sign off the lexus.
Just try running the lexus with the iphone and see what you get, so you have another datapoint.
Originally Posted by Dakota Kid View Post
This has become quite the interesting thread. I will eagerly await the results of your run in Bonnies car!
Running this weekend.
Originally Posted by TheClassicCarKid View Post
Did you feel any difference between the ~6 second runs and the dynolicious run?
Funny you should ask that. Yes, it did seem faster. I watched the speed climb and when the run was over I KNEW it would read good. Wasn't sure what to expect but I did forget to look at the shift point out of first gear.
Old 07-02-2009, 02:44 PM   #59
DDustiNN
DDustiNN's Avatar
Drives: Soon: 2016 Camaro SS
I haven't done any racing yet, nor any timed runs of any sort, but I definitely do not feel like this car lacks power. If I gun it, I actually feel myself getting slammed back to the seat. I'm only at ~300 miles though, and I've kept it under 4k rpm, so I can only imagine what it will be like later! So far, I am incredibly pleased
DDustiNN is offline   Reply With Quote
Old 07-02-2009, 02:45 PM   #60
PQ
Booooosted.
PQ's Avatar
Dynolicous. If they are accurate then I'm absolutely happy with it. Not sure how accurate the numbers can be. Considering I was about 200+ pounds light on the weight I put in for the car (I put 3800 lbs.) then even the HP numbers would be about 15 to 20 higher whitch would put it in the range.
Old 07-02-2009, 02:47 PM   #61
redjewel
Drives: 2010 Camaro 2SS RJT
If it is just the learn thing FBodfather described I sure don't like that. My wife will drive the car more frequently and not as hard as I will. When I am in the car I don't want to get beat down by a lexus or even a Ford Mustang GT or Challenger because the car learned it is not being pushed very hard. It is a V8 with 400 HP and it should unleash that HP whenever I freakin want it to. That being said I have driven the car more aggressivley and I don't believe I have a currentl power issue. But currently I have put over 550 of the 640 miles currently on it.
Just a side note I changed the oil today reset miles per gallon and I am magically getting 17.4 over the previous 14.2. And after the oil change I really opened her up several times.
redjewel is offline   Reply With Quote
Old 07-02-2009, 02:48 PM   #62
PQ
Booooosted.
PQ's Avatar
Well, that's the only common thread me an Scott seem to have. I think we babied ours too much. If I had it to do over again I'd run it wide open from the beggining. Mine seems to be possibly shaping up now that I'm full throttle all the time.
Old 07-02-2009, 02:51 PM   #63
PQ
Booooosted.
PQ's Avatar
IF it's a computer 'learning' thing, it may be a threshhold deal. Where it sets to the highest level you drive at. Then it would allways be there.
Old 07-02-2009, 02:59 PM   #64
redjewel
I would hope that you are correct and your car was broken in according the manual and your computer learned a lower threshold. I am afraid the computer may learn the average driving habits and set itself according to those paramaters.
Imagine beating your car to redline all the time and getting max HP. Now say Bonnie drives it for a few months and gets on it some but not like you. Is the computer going to relearn her habits as it did yours for the first 1500 miles Just imagine letting someone else drive it more conservativley for a while. Is this going to be the what happens? I sure hope not and that you are more correct in it setting a threshold at the highest level driven.
I say if you ask for 400 HP the computer should give it to you regardless of what it thinks it has learned.
Old 07-02-2009, 03:10 PM   #65
PQ
Booooosted.
PQ's Avatar
Size:  23.0 KBName:  1231_hysterically_laughing.gif
Old 07-02-2009, 03:13 PM   #66
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I bought a car that cost me 37K and I want the 400HP 0-60 4.7 performance I was told it would have. I do not want some silly thing learning that since I do not get on it everyday it will be slow today
Scott@Bjorn3D is offline   Reply With Quote
Old 07-02-2009, 03:16 PM   #67
PQ
Booooosted.
PQ's Avatar
Originally Posted by Scott@Bjorn3D View Post
I bought a car that cost me 37K and I want the 400HP 0-60 4.7 performance I was told it would have. I do not some silly thing learning that since I do not get on it everyday it will be slow today
Where's Bruce? Get the camera.
Old 07-02-2009, 03:20 PM   #68
redjewel
Yeah I expected that too.
2SS RJT A6 Sunroof Polished Wheels. Delivered 5-22-09 by Classic Chevrolet Sugarland
Old 07-02-2009, 03:54 PM   #69
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
Not bad. Based on your 1/8th MPH, your car would have trapped ~105.3, which I think seems right.
THE EVIL TW1N is offline   Reply With Quote
Old 07-02-2009, 04:36 PM   #70
Yamatr3
Yamatr3's Avatar
Drives: 2006 Pontiac Solstice LS2
These guys tested Dynolicious and concluded it is accurate.
Yamatr3 is offline   Reply With Quote
LS3 vs L99? SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 09-18-2010 04:55 PM
L99 owners with slow cars going to dealers for fix. Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 131 12-21-2009 03:30 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
L99 Owners, Tell Me About Your Car and Stuff Scott@Bjorn3D 5th Gen Camaro SS LS LT General Discussions 0 04-26-2009 09:33 AM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
