Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 06-21-2013, 11:01 PM   #1
Demon Z/28
Scarecrow
Demon Z/28's Avatar
Drives: like a granny
Bought a new Tig Welder, now to learn how to Tig !
I'm pretty excited. Ordered it a few nights ago. It's a Miller Diversion 180. need something to help pass the time until the camaros hows up. So i decided to finally get a Tig welder and maybe start messing around a bit.
Why Tig? the challenge and the cleanliness.
If anyone has any tips on starting off, i'm all ears. Hell, if ya wanna brag about yourself, post up some pics of your welds.
The Rooster - 2015 Z/28
The Scarecrow -2014 1LE SOLD -
Demon Z/28 is offline   Reply With Quote
Old 06-25-2013, 06:11 PM   #2
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
I've been thinking about the same welder. Post your results.
Cam 427 is offline   Reply With Quote
Old 06-25-2013, 06:14 PM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I TIG welded for about 12 years. There are a lot of people who think they can TIG, but really can't. Best advice I can give is go slow when you start.
SUX2BU is offline   Reply With Quote
Old 06-25-2013, 06:46 PM   #4
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
Agreed!!! I welded for about 12 years as well, there is an art to it, especially with exotic metals, aluminum, chrome moly, ect!!
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune...
ToolFan66 is offline   Reply With Quote
Old 07-01-2013, 02:40 PM   #5
Demon Z/28
Scarecrow
Demon Z/28's Avatar
been watching youtube videos and what not but haven't fired it up yet. Awaiting a power cord with adapter to run off my unused dryer outlet.
Old 07-04-2013, 09:12 AM   #6
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
From your trusted mod, CamaroSpike23
"Cut soda cans in half and weld them back together to practice tig welding."
Old 07-04-2013, 02:33 PM   #7
Demon Z/28
Scarecrow
Demon Z/28's Avatar
thats some thin chit man.
i'm liking this idea
Old 07-04-2013, 02:44 PM   #8
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
You need to practice indoors as a slight breeze will contaminate your weld. Tenting with weld shields or tarps can help outdoors.
Chassis work is easiest cause it's thicker, body work takes patience and staggering welds to avoid warping.
Irnwkrkev is offline   Reply With Quote
Old 07-04-2013, 03:40 PM   #9
Demon Z/28
Scarecrow
Demon Z/28's Avatar
I have a wooden craftsman work bench that i put a large sheet of steel on top of. This is in my garage and will be my practice area. i can limit airflow with the garage doors. Still just waiting on my power cord. looks to be monday for that.
I bought steel and aluminum rods as well as 100% argon. I am unsure which to do first or more of. After watching that video though, i feel aluminum may be the best option since it cools so much quicker and doesn't require constant cleaning.
I'm having a tough time understanding the walking the cup. I can see how it works but pretty much all of the videos i watch, they aren't doing that method.
looked up the cut a can in half and didn't find anything about that. did find people welding the bottoms together.
heres an update to the previous video. like this one more because i'm able to see whats too much (somewhat) and what causes certain things. can't wait to fire my welder up.
http://www.youtube.com/watch?annotat...&v=vWNZioJ_FOc
Old 07-04-2013, 05:48 PM   #10
Mr Twisty
Mr Twisty's Avatar
Welding aluminum cans together is advanced class. Start with thick stock and work your way down.
Practice running beads on fairly thick sheet, then cut it up and check your penetration. Bad welds can look pretty.
-- Benjamin Franklin
Old 07-04-2013, 06:04 PM   #11
Mr pogo
Drives: 96 Imp SS, 13 Camaro 2SS AGM
study up on oxy-acetylene welding techniques, they apply directly to freehand tig welding.
back decades when I worked for Foster Farms I had free use of the tig welder besides using it for work, used to make fan shrouds, motorcycle chain guards and other chit.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=71668&dateline=136924  9466
Mr pogo is offline   Reply With Quote
Old 07-04-2013, 07:14 PM   #12
ToolFan66
ToolFan66's Avatar
Use helium or helium argon mix for aluminum, and argon for steel, and stainless.
Old 08-15-2013, 01:24 PM   #13
EarlyApex
Drives: 2013 IOM 2SS 1LE
1. Get an auto darkening helmet, it will make it easier to start a arc and see what you are doing.
2. Straight argon is fine for most of the welding a DIY will ever do.
3. Go to www.weldingtipsandtricks.com for excellant training videos.
4. Practice practice practice.
Good luck and have fun
EarlyApex is offline   Reply With Quote
Old 08-15-2013, 01:50 PM   #14
CFD
Drives: 2SS/RS L99 BLACK
Straight Argon is ok, with a 180 amp machine preheating thicker aluminum pieces will make it much easier, clean your work with stainless steel brushes, learn proper grinding of the tungsten this is important to control arc. When learning, most find steel much easier to weld than aluminum.
CFD is online now   Reply With Quote
