Gen5DIY
Old 06-22-2013, 09:24 AM   #1
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
screw sizes for cai
I lost the screws that hold in place the masflow sensor. For the cai introduction kit. Going to home Depot thanks.
Johnthegreat is offline   Reply With Quote
Old 06-22-2013, 09:25 AM   #2
2Carats
2Carats's Avatar
Drives: '12 Camaro 2SS/RS LS3
Dayum that sucks!
Mind controlled by Cerebro
I solve problems for a living. Either accept my advice or go figure it out on your own.
2Carats is offline   Reply With Quote
Old 06-22-2013, 09:29 AM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Cool close up of your avatar!
Old 06-22-2013, 09:40 AM   #4
Johnthegreat
Dude why are u hung up on my pic? If u don't like it dont respond to my post and I won't have to look at it.i have nothing better to do?
Old 06-22-2013, 09:42 AM   #5
Johnthegreat
I mean u have nothing better to do? I need help not ur sarcasm.
Old 06-22-2013, 02:01 PM   #6
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
litle is just busting your balls man he didnt mean disrespect since this is a 95% male forum its just weird to see actual ppls faces on their avatars. so that being said being a highly populated male forum youre going to take som heat from some of th guys just a heads up.
Nightmare2012 is offline   Reply With Quote
Old 06-22-2013, 02:11 PM   #7
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
So just walk into the store with the intake pipe and get the screws you need. Problem solved.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 06-22-2013, 05:53 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This or maybe CALL CAI to see what they recommend.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-23-2013, 08:18 PM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Don't sweat it man that avatar is awesome !!! You should find a way to make it bigger. I sure hope your able to replace those screws.
Mchlgrrsn is offline   Reply With Quote
