Emblempros
Old 06-22-2013, 10:08 AM   #1
Suprslo
Drives: 2013 SS
2nd time to the track... Better but not good
So I posted last month my times for my first time to the dragstrip. I took everyone's advice and made some changes. All I was concerned with last night was 60 ft times. My first time out I couldn't get better than 2.2-2.3. So last night I dropped the tire pressure to 20lbs and did longer burnouts and was able to cut consistent 2.0 60fts. So it's better but not where I think I should be. Anyone have anymore advice for me to get sub 2.0 60? Tires are 315 DR's and M6 trans. 3.91 gears. (20 inch rims) thanks
Suprslo is offline   Reply With Quote
Old 06-22-2013, 12:58 PM   #2
blufin
blufin's Avatar
Drives: Fire Engine
Bogging or spinning?
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 06-22-2013, 01:20 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
+1 also, any wheel hop?
Click to view my build thread
Old 06-22-2013, 04:09 PM   #4
Suprslo
Drives: 2013 SS
No wheel hop. I was getting the 2.0 spinning. When it bogged I was 2.1-2.3.
Old 06-22-2013, 04:50 PM   #5
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Ride that clutch out my friend. With 20's it's the only way you will do it. So hopefully you have a beefy clutch.
I would honestly recommend dropping the 20's and getting a set of 18's with radials.
xjer22x is offline   Reply With Quote
Old 06-22-2013, 08:18 PM   #6
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
^ yep! Ride or die!
Camarojt is offline   Reply With Quote
Old 06-22-2013, 09:38 PM   #7
blufin
blufin's Avatar
Drives: Fire Engine
Originally Posted by Camarojt View Post
^ yep! Ride or die!
All truth here. Slipping is an art and takes some time to get it down. Seat time is your friend.
Sold
Old 06-22-2013, 09:56 PM   #8
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
What RPM are you leaving at? I just got DRs on 18s and it took me 6 passes before I figured out what I was doing wrong! My car was bogging or I was letting off the clutch to fast, what worked on my last 2 passes was 5k rpms and a quick slip of the clutch, I ran 1.80 60ft but missed a gear and blew the run!!! Tried it agian and pulled 1.87... Lucky you have 3.91s so you may only need 4000-4500 to do this.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 06-22-2013, 10:55 PM   #9
Suprslo
Drives: 2013 SS
5k!! No way I could do that. I was leaving closer to 2500 - 3000. From the responses it seems I need to ride the clutch more. Even better get smaller rims and more tire. I'm going back this Friday so I'll give it a shot.
Old 06-22-2013, 11:01 PM   #10
xjer22x
xjer22x's Avatar
Yeah, a 5k launch will destroy your stock clutch quick. I'd say at most 3500. But play around, blufin nailed it. Just takes seat time.
sent from my galaxy s3. that would explain the errors.
Old 06-23-2013, 12:23 AM   #11
Suprslo
Drives: 2013 SS
I have a RPS twin carbon clutch. The clutch is great and can take the abuse but launching at 5k seems crazy when I'm spinning at 3k
Old 06-23-2013, 02:16 AM   #12
2010SSRSM6
2010SSRSM6's Avatar
I was able to cut a 1.93 on the stock Pirelli's (28 psi) launching at 2k and quickly slipping the clutch as the loud pedal got closer to the floor.
What Dr's are you using?
Old 06-23-2013, 02:47 AM   #13
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
With those DR's you should be getting 1.6-1.7's all day long.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 06-23-2013, 11:26 AM   #14
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i can cut 1.8 on the stock tire . almost every time. took lots of practice to learn what the car wants tho. dont just keep tryin the same thing over and over try different stuff. but most likely uneed to slip a lil more and less gas then start working ur way up on the gas . is the track known for having good prep. That could be ur problem.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
