B&M Racing
Old 06-22-2013, 01:56 PM   #15
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
That will help a bunch for sure.
xjer22x is offline   Reply With Quote
Old 06-22-2013, 01:58 PM   #16
JEFF75645
Drives: his wife crazy buying mods
I was also going to upgrade my cam and heads, but I can't even put the power down now. Gonna work on suspension first. The results from last night made it very clear.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 06-22-2013, 02:02 PM   #17
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Originally Posted by blufin View Post
I don't know about 11's, but you've definitely got some room to improve. The heat and humidity are also hurting your times as our cars don't like the heat. Raise your tire pressure back up to around 30-32. IMO, 25 is too low for a stock tire. I've managed 1.6-1.7 short times on stock tires at 32 lbs.
This car should easily run 11's! 2 factors that he needs, TIRES & DA!
Aren't you cammed Jeff? And stalled? PTB and Ported heads?
Camarojt is offline   Reply With Quote
Old 06-22-2013, 02:06 PM   #18
JEFF75645
Yep. I've got everything you listed.
Old 06-22-2013, 02:14 PM   #19
xjer22x
xjer22x's Avatar
It is possible to get better 60fts with stock suspension. I have completely stock suspension and rear end and i can run 1.7-1.8 all day long.
But it definitely wouldnt hurt. The biggest opportunity you are missing out on right now are the tires.
Old 06-22-2013, 02:27 PM   #20
JEFF75645
I agree. So as of yesterday bigger cam and milled heads are on the bottom of the list. Suspension mods and 18" wheels with slicks are first.
Old 06-22-2013, 02:28 PM   #21
Camarojt
Camarojt's Avatar
But it definatly wouldnt hurt. The biggest opportunity you are missing out on right now are the tires.
^^ you don't need to worry about suspension in an A6! I've cut 1.56 60fts on just a bolt on car with 365hp!
Rhino cuts 1.48 I believe and he's still running stock suspension.
Spend that money on tires and some lighter wheels.
Old 06-22-2013, 02:32 PM   #22
xjer22x
xjer22x's Avatar
I think this is a better idea. Master putting down the current power level you are at now, before adding more to your plate.
It will just make it that much more difficult to put it down then.
Old 06-22-2013, 02:34 PM   #23
JEFF75645
Cool. If the stock suspension will hold as it is them I can have the wheels that much quicker.
I lost a race last night I should have won due to shitty stock tires. But gave that M3 hell all night.
Old 06-22-2013, 02:39 PM   #24
xjer22x
xjer22x's Avatar
Yeah it will hold for sure.
general rule of thumb is every tenth you can knock off of you 60ft... doubles at top end.
So roughly look at it as if you could knock 1/2 a second off your 60ft and get down to a low 1.7 for example... That would be close to a full second off your 1/4 time.
Old 06-22-2013, 02:44 PM   #25
JEFF75645
I noticed also that at some points its shifting very quickly. I shifted 2 times in a second or two past the 1/8. Is this just the stall doing its thang?
Have yall had a chance to look at some of the videos?
Old 06-22-2013, 02:49 PM   #26
xjer22x
xjer22x's Avatar
do you mean shifting quickly as like at a low RPM, or as in like the amount of time it took to go from one gear to the next was quick.
and i am at work where youtube is blocked. So i will look later.
Old 06-22-2013, 02:53 PM   #27
JEFF75645
Its at higher rpm. around 5000-6000 it shifts then shifts again a second or 2 later. and runs until the end.
Very noticeable in the first video. Check it out later. Maybe Im just over analyzing it.
Old 06-22-2013, 03:07 PM   #28
xjer22x
xjer22x's Avatar
With that description sounds like your shift points need to be reconfigured.
Do you log at all while at the track? and yeah, i will check them out when i get a chance.
