Caryle Racing
Old 06-22-2013, 03:14 PM   #29
JEFF75645
Drives: his wife crazy buying mods
I sent all of the videos to my tuner. He is out of the country right now though. It appears not to be running out to 6000 in 3rd. Short shifting? On the vacant back roads I can run 3rd out to about 117 but the track is different I guess.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 06-22-2013, 03:23 PM   #30
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
I wonder if tire slip is causing it to upshift too early?
CamaroTom is offline   Reply With Quote
Old 06-22-2013, 04:47 PM   #31
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Just watched the videos and its very possible the tire spin could be throwing it off.
But yeah your 2-3 shift comes very quickly. And your 3-4 shift is actually hanging up a little bit too.
I wouldn't try and trouble shoot anything until you get some better rubber on those tires. With your power levels you are gonna struggle greatly to get traction.
xjer22x is offline   Reply With Quote
Old 06-22-2013, 04:57 PM   #32
white ZL1
Drives: none
Originally Posted by Camarojt View Post
^^ you don't need to worry about suspension in an A6! I've cut 1.56 60fts on just a bolt on car with 365hp!
Spend that money on tires and some lighter wheels.
This. All night.
And quit bragging.
I'm going to steal your converter out of your car and go 11.49 next fall with some awesome DA.
white ZL1 is offline   Reply With Quote
Old 06-22-2013, 04:58 PM   #33
blufin
blufin's Avatar
Drives: Fire Engine
This car should easily run 11's! 2 factors that he needs, TIRES & DA!
Aren't you cammed Jeff? And stalled? PTB and Ported heads?
True that. I was referring to him staying with the stock tires. Cutting his 60' down to a 1.7 on stock tires at that power level is a stretch.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 06-22-2013, 06:37 PM   #34
Juice2SS
Drives: 2011 2SS
Ya, you short shifted from second to third. That is killing MPH I'm sure of it. You are spinning at all times during your pass. Crandall did that too me too. :-/ You need some 18" Grand Sport wheels and some MTs.
Juice2SS is offline   Reply With Quote
Old 06-22-2013, 07:43 PM   #35
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I just watched some of the vids, and it sounds like it shifted 2-3 quickly on some of the early passes.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-22-2013, 07:50 PM   #36
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
From what I can tell it's either your shift points are off Or ....
Before I say the other possibility, (do you have a multi disc converter?)
Camarojt is offline   Reply With Quote
Old 06-22-2013, 07:51 PM   #37
JEFF75645
Yes I do^^^
Old 06-22-2013, 07:55 PM   #38
Camarojt
Camarojt's Avatar
Originally Posted by white 2SS/RS View Post
This. All night.
And quit bragging.
Haha! I'm gonna steal your gears and put them in my car and break all the records! Then I'm gonna put your car on a diet, then I'm gonna drive it and THEN it will run 11.39!!
I see now and yes you are right. Ut would be hard for him to see 11's in stock tires, and a 1.7 on stock tires at his power level is gonna be almost impossible!
Old 06-22-2013, 07:57 PM   #39
JEFF75645
I guess I need slicks, gears, and a little slim fast in the gas tank to keep up with y'all.
Old 06-22-2013, 07:58 PM   #40
Camarojt
Camarojt's Avatar
Originally Posted by JEFF75645 View Post
Yes I do^^^
Thought so, it also could be your converter locking very early. You need to data log it to see exactly what it's doing.
Either way if its shift points or converter lock up mph, it needs to be adjusted!
I hope your tuner has the ability to tune your converter. Not all tuners can! Trust me I know.
Old 06-22-2013, 08:03 PM   #41
JEFF75645
On the street when driving in manual in 2nd or 3rd when I shift into those gears the car surges very noticeably. I will shift and a few seconds later it will surge and drop rpm. It does it in s mode but not as hard. I don't know if this is related to what you are talking about. He said it should lock until 4th.
What do I need to log my runs?
Old 06-22-2013, 08:14 PM   #42
Camarojt
Camarojt's Avatar
How where you shifting it?? In S and let it shift on its own?? In M and paddle shifting it?
I just noticed that towards the end of the night, it wasn't doing that short shift or converter lock up like it was earlier? Did you change your launch technique or anything?
