Old 06-22-2013, 08:45 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Installed Headers today
I just installed a set of Kooks 1-7/8 long tubes and hi-flow cats today. Now I was told I would need a tune, but I'm surprised how bad it runs by just changing the headers. It feels like I lost 50 hp. Can't wait till the SCT 3400 shows up and Jannetty's tune goes in it. I hope it runs like a raped ape .
Craig B is offline   Reply With Quote
Old 06-22-2013, 08:54 PM   #2
aggieguy13
aggieguy13's Avatar
Drives: 2013 SS/RS VR 1LE
because the pressure all all way different. the engine is going to flow gas into it trying to get the A/F correct
aggieguy13 is offline   Reply With Quote
Old 06-22-2013, 09:49 PM   #3
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Sounds better though right??
edit: (would love if you posted a sound clip/vid)
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake | Pfadt Suspension | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 686rwhp/590rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 06-22-2013, 10:05 PM   #4
Craig B
Craig B's Avatar
Drives: 2013 1LE
I thought it would have been louder. I also have Flowmaster mufflers [American thunder] I may make a move to the outlaws. I will see how it sounds when it's running right.
Old 06-22-2013, 10:12 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The high flow cats is what's keeping it quieter. You should have gained a fair amount of HP though. Are you sure you got all the spark plug wires on tight? It's not hard to miss one.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-22-2013, 10:27 PM   #6
Craig B
Craig B's Avatar
Drives: 2013 1LE
I'm going to take a look and make sure.
Old 06-22-2013, 10:51 PM   #7
Dynamite
Dynamite's Avatar
Drives: 2013 Camaro 2SS/RS XD
I have headers installed without a tune and the car definitely feels a bit faster.
Dynamite is offline   Reply With Quote
Old 06-22-2013, 11:28 PM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15STI,'10Expy,'10 2SS/RS M6,'47KB1
No matter what others say, that you don't lose bottom end power, it still feels like I did. Even after the tune. Never dyno'd before and after, so no proof. The rpm's do climb faster and pulls harder on top.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 06-22-2013, 11:37 PM   #9
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Wow. My car was night and day faster and stronger when I put my headers on. Now I did have to run my stock intake because the stock tune didn't jive with the it and the headers. Once I got it tuned with my intake it smooth it out though.
Old 06-23-2013, 12:04 AM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
Damn, This is new to me even without a tune a header swap most of my older LS toys felt real strong. Some on here dynod good numbers without a tune. Maybe its in your head???? Either way hope it runs strong with the tune
62nalide is offline   Reply With Quote
Old 06-23-2013, 02:09 AM   #11
trw427ss @ Futral
trw427ss @ Futral's Avatar
Drives: 2013 2SS/RS L99
My car picked up almost .35 and 3 mph after I installed LT's WITHOUT A TUNE!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss @ Futral is offline   Reply With Quote
Old 06-23-2013, 02:17 AM   #12
luvmy5thgen
luvmy5thgen's Avatar
Drives: 2010 camaro 2SS/RS
I have a stock 2010 L99 and my first mod is Kooks LT and full exhaust.. putting it on tomorrow... I hope it runs better ..
luvmy5thgen is offline   Reply With Quote
Old 06-23-2013, 02:27 AM   #13
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
Interesting...right away I could tell I had more power after my LT's. Check to see if all the spark plugs are connected...also if you didn't remove the spark plugs they can crack easily.
Good luck...I'm sure it will work itself out
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 06-23-2013, 04:08 AM   #14
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Definitely check your spark plugs and wires. Car felt much stronger after install, but about 150 200 miles later I had a misfire and the car was very sluggish and had little power. I just found that one of my wires wasn't even attached to the spark plug. Not sure if the installer forgot to reattach it or if they just didn't secure it all the way and it popped off. But yeah, check your plugs and wires because it will make a huge difference!
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
