Old 06-23-2013, 06:06 AM   #1
l3lomi
Drives: 1999 camaro ss
99 camaro ss engine rebuild,help!!!!
Ok so I have a 99 camaro as with a 5.7ls1 and about a month ago I went through some flood water and messed it up so a friend of mine is saying I probably just need to suck the water out of the cylinders and ill be alright so I'm gonna try that tomorrow but I'm case that doesn't work any suggestions or even if you guys could tell me about some engine rebuild shops that are good and keep in mind I'm a 22 year old college student I can't afford a 10000 engine rebuild I'm in Houston Texas so any info will help thanks guys
l3lomi is offline   Reply With Quote
Old 06-23-2013, 09:47 AM   #2
Learjetguru
Learjetguru's Avatar
Drives: 2011 2SS LS3
Drain the oil, transmission fluid and rear end lube, Pull the spark plugs ( the back two are a
@#$%^&& If it will crank. Motor the engine approx 5 sec. Pull the oil filter and install a new one. Add 4 quarts of oil. Put the plugs back in. service the trans and rear end. See if it will start. If it starts and runs you might be ok. Change the oil & filter again.. Good Luck
2011 Camaro 2SS
1969 Camaro BB 472 NOS
1997 Camaro Z28
Learjetguru is offline   Reply With Quote
Old 06-23-2013, 11:01 AM   #3
l3lomi
So today we took out the spark plugs and we put a little hose in to see if we could suck any water out but it was pretty much free of water just enough to tell that there was water in it but not enough to actually suck any out just an update not sure where to go from there with what you mentioned...ps my phone was acting weird when I made this thread so there might be multiple threads now now,sorry
Old 07-03-2013, 06:42 PM   #4
Evil35th
Drives: 02 35th Aniversary SS/'11 RJT 2SS
i know i may be a little late, but spray the cylinders with a little wd 40, and roll the motor over. If the engine turns over fine, just flush ALL the fluids and you should be good.
02 35TH LE#3089 and 2011 2SS/RS
Evil35th is offline   Reply With Quote
