Old 06-23-2013, 03:27 PM   #1
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
How hard would it be to swap 1LE brakes on my SS?
I'm looking at buying the full 1LE brake setup with the spindles, rotors, calipers etc.
How much spring tension is there on the struts front and rear? I was all ready to do the swap but now I'm beginning to worry about it.
Is it just popping off the knuckles at the bottom of the spindle on the fronts? Using a floor jack to support the lower control arm and just unbolting and transferring the 1LE stuff over to the strut?
On the rears; It appears you remove the nut on the rear hub and slide it out or is the hub attached using a C-clip?
I'm a little lost on the rears but the fronts seem pretty straightforward.
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is offline   Reply With Quote
Old 06-23-2013, 03:33 PM   #2
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
Excuse my ignorance, but aren't the 1LE brakes just SS brakes powder coated red?
Falundir is offline   Reply With Quote
Old 06-23-2013, 03:34 PM   #3
Nutro
Nutro's Avatar
Same but red calipers and HD bearings.
Old 06-23-2013, 03:44 PM   #4
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
And I believe the HD bearings in the rear require a different axle shaft. Honestly, I would just swap everything but the knuckles and bearings over. Don't really see a need for the HD bearings unless your tracking your car HARD. You can also swap the bearings over without touching your knuckles. Then you don't need to pay for an alignment.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 06-23-2013, 04:10 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
The axle shaft are the same where they meet the brakes and diff, its the CV that is biger in the axle shaft's.
