Solo Performance
Old 06-23-2013, 03:42 PM   #1
11Huggerwhite
11Huggerwhite's Avatar
Drives: 2013 Camaro SS supercharged
Nitrous
I want to add nitrous to my car but want to know what the best kit is. What's the most I can spray on the stock bottom end somewhat safely. The car is making 620whp on blower now. Thanks.
11Huggerwhite is offline
Old 06-23-2013, 03:43 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
You're pretty much at the stopping point for a stock bottoms end right now...
I Ain't About That Stock Life.
2SS45th is offline
Old 06-23-2013, 04:18 PM   #3
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Do you have a fuel system to support it?
Trackman is offline
Old 06-23-2013, 04:49 PM   #4
Birm
Birm's Avatar
Drives: Florida Speed & Power
http://nitrousoutlet.com/index.php/f...te-system.html
Route I'd go personally. With a few additions of course (window switch, LPE Launch & Timing Controller #LNC-2000)
Birm is offline
Old 06-23-2013, 07:06 PM   #5
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
nitrous outlet , lnc-2000 , nos launcher. spray a small shot like a 25 or so with ur setup.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline
Old 06-23-2013, 08:52 PM   #6
grocerygetter
instigator
grocerygetter's Avatar
interesting...we had this discussion at the track last night. I'm wanting to spray like a 75 shot (would put me right on 600whp)...I think in the heat we have down here that it would actually make the car more consistant. Centris are way cooler running than the roots options, but this totally changes the ball game.
Make sure you have fuel, and +1 on the Lingenfelter timing controller.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
grocerygetter is offline
Old 06-23-2013, 09:24 PM   #7
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
There is people running over 900whp with stock shortblocks. With boost and bottle. Just make sure you put some good fuel in there with a good tune. and you will be fine on the bottle with a 75 shot
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline
Old 06-23-2013, 09:27 PM   #8
Supercharged SS
Drives: 2010 Camaro
OP, you can just go with a dry shot as long as your fuel system / injectors can handle adding the extra fuel and your tuner knows what he is doing. And as long as your trans can handle spraying through the shifts
I'm having good success with that setup. Mine is on a WOT switch and that's it. Once I floor it the nitrous sprays until I cross the traps.
Supercharged SS is offline
Old 06-23-2013, 10:13 PM   #9
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
I'm spraying a 100 ontop of the blower. 900whp stock bottom
VanquisherSS is offline
Old 06-23-2013, 10:14 PM   #10
Supercharged SS
Drives: 2010 Camaro
On the dyno isn't the same as the track. Hold it wot for 10 seconds then report back.
Old 06-23-2013, 10:28 PM   #11
VanquisherSS
I was doing plenty of that blasting through the pine barrens of NJ with a few other cars. I was WOT into 5th if you get my drift. . On another note the differential is holding up LOL
Old 06-23-2013, 10:30 PM   #12
Supercharged SS
Drives: 2010 Camaro
I highly doubt you were using 900 rwhp on the street. Actually, there is no way you were. The road would never ever hold that. Not to mention you'd punt the car in front of you.
Old 06-23-2013, 10:37 PM   #13
VanquisherSS
Well, there was legit no cars in front of me lol, you haven't been to the pine barrens then? My buddy in the vette behind me could chime in perhaps and verify as he wanted to see if he could keep up. Of course there was spinning a bit but once I hit 3rd it hooked right up from a 2nd roll.
It was fine all day on 750whp don't see why you think adding a bit more power is unfathomable. Not like the road shatters under the power LOL
Old 06-24-2013, 01:37 AM   #14
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
Plenty of people run over 1000whp and exclusively street race. Yeah, it's dangerous and the traction won't be as good but it's not like it's impossible, especially at higher speeds.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline
