Emblempros
Old 06-23-2013, 03:59 PM   #1
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Gmpp cnc ls3 heads
Wanting to know if anyone is running these. For what I'm looking to do this might be my best route. Running stock cubes with d1 Procharger making 900 hp. I know the boost will dictate the power but I don't need a super custom cnc job just a little more air flow to free up the n/a power so I can run less boost lets hear some pros or cons.
http://www.jegs.com/webapp/wcs/store...=&pgGrp=search
Trob85 is offline   Reply With Quote
Old 06-23-2013, 04:08 PM   #2
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
What size cam.... seems like valve spring are not that good with
.550" max valve lift with installed springs
I had to go bigger with my cam
meshamey is offline   Reply With Quote
Old 06-23-2013, 04:13 PM   #3
Trob85
Svt lol
Trob85's Avatar
I'm running the Lingenfelter gt9 cam I would just replace the springs with .675 prc set
Old 06-23-2013, 04:51 PM   #4
SPCBA
Drives: pleather and Chiclets
west coast heads. if you want a custom port polish and mill job on the heads go to the best and do it once
SPCBA is offline   Reply With Quote
Old 06-23-2013, 04:55 PM   #5
Trob85
Svt lol
Trob85's Avatar
That's what I'm saying I don't need a custom porting job just a little more air flow which these have.
Old 06-23-2013, 04:58 PM   #6
429
Drives: 2010 camaro ss
You're making 900 on a D1 on stock cubes and heads?
Uh, I'd like to see this setup... because I don't see it happening.
429 is offline   Reply With Quote
Old 06-23-2013, 05:10 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
OP do you mean that you WANT to make 900hp and are looking for heads?
Tell me more about your setup, I'm curious too sir.
Old 06-23-2013, 05:10 PM   #8
Trob85
Svt lol
Trob85's Avatar
You don't need a huge displacement to make big power several guys I know are running the same setup forged internal 376 ci ls9 cam ported heads full exhaust 102 octane making 875 to 910 hp at the crank not the wheels
Old 06-23-2013, 06:42 PM   #9
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 06-23-2013, 07:28 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I know what it takes, just wanting to see the op's setup.
Old 06-23-2013, 07:36 PM   #11
Trob85
Svt lol
Trob85's Avatar
That was ment for 429 stock crank Callie's h beams wiseco -11 pistons d1sc ported heads Aeromotive fuel system running e85 stock intake and throttle body long tubes with 3 inch straight pipe no cats.
Old 06-23-2013, 07:53 PM   #12
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
I just put these on mine. Haven't driven it too much but does seem a little peppier ( if that's a word) for the little bit I have. I was on a time crunch to get my motor back together for a track day and went with these. One thing you will definitely need are the two rivets to plug the steam vents that will be at the back of the engine. I didn't realize this until I had mine all back together. And filling with antifreeze then started to hear the antifreeze dripping all over the place.
1977and2010 is offline   Reply With Quote
Old 06-23-2013, 07:58 PM   #13
Trob85
Svt lol
Trob85's Avatar
What steam vents are you talking about the ones with that crossover pipe. Could you post up a picture.
Old 06-23-2013, 08:46 PM   #14
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
He's talking about the steam vents. The Ls heads have a steam/ coolant tubes at each end of the head and there are freeze plugs at the back, one on each side. They must be plugged or used and connected back to the coolant system. I reconnected all of mine to avoid any hot spots in the head since I was going to have 12.25 to 1 compression. I used the L98 truck crossovers and then t'd it to the front ones.
cnc, gmpp, ls3heads
