Gen5DIY
Old 06-23-2013, 06:30 PM   #1
tillroot1
tillroot1's Avatar
Drives: 2010 Camaro SS
loping, surging or a missfire?
I hope to find a little help here, I have a 2010 2ss 6.2 6manual car, it has a dyno tune, CAI, ARH complete system, and a polished throttle body. almost 50,000 miles on it. Lately in the 1000 to 1500 rpm range while decelerating or holding that rpm range in the lower gears such as surface street speeds, the car has a surge, or a lope or a misfire. I changed the spark plugs, they all looked great, so I am confident they are not the problem. Any ideas or suggestions? thanks for any offered. Ron TIlley
tillroot1 is offline   Reply With Quote
Old 06-23-2013, 06:33 PM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Could be a bad plug wire.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-23-2013, 06:36 PM   #3
tillroot1
tillroot1's Avatar
its wierd, it idles smooth, has strong power but only affected at lower rpms and the plugs all looked exactly the same.
Old 06-23-2013, 07:09 PM   #4
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
Might want to check your o2 extensions one of my got burnt had same type if issue
MARINE1991 is offline   Reply With Quote
Old 06-23-2013, 07:48 PM   #5
tillroot1
tillroot1's Avatar
I will do that, Thank you.
