JUICEDMOTORSPORTS
Old 06-23-2013, 07:32 PM   #1
NJ-JRS
C5
NJ-JRS's Avatar
Drives: 2012 2LT/RS Red accents on Black
10-14 mpg city on 2012 LT?? (video link inside)
Hi Guys,
For some reason (I expected my CAI filter at first but now not so sure) I'm getting horrible MPG this summer compared to last, but I don't think I'm driving any differently. Here's a quick video I took last night without driving too aggressively:
http://youtu.be/HL4KoL7txT0
Can this possibly be right? I'm consistently only getting about 10-14 mpg driving locally. If it wasn't for times of coasting with foot off of pedal I'd probably be in single digits. I have no idea what this could be. The car sat most of the winter; started summer with an oil change. I tried re-oiling CAI intake filter twice now, also used MAF sensor cleaner and tried ECU fuse pull for the hell of it. Nothing helped; only other mod within engine compartment is catch can.
Any ideas what would be causing such low mpg now when I haven't changed anything on the car since last summer? I'm not sure where to even start troubleshooting this.
Thanks.
NJ-JRS is offline   Reply With Quote
Old 06-23-2013, 07:52 PM   #2
benji1997
benji1997's Avatar
Drives: 2013 IOM 2LT/RS M6
Send a message via Skype™ to benji1997
Take the car onto the turnpike and reset the mpg gauge, then drive for about 20 miles to see what you get on the highway.
2013 2LT/RS IOM M6 w/DUAL-MODE EXHAUST, BLADE WING SPOILER AND ZL/1 PERFORMANCE PEDALS
benji1997 is offline   Reply With Quote
Old 06-23-2013, 08:14 PM   #3
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
You can't go by little short runs, resetting your mpg readout. By that method, if you want to feel really good about mpgs, go out in the country and find a nice long downhill run. Reset the mpgs and drive a mile or so giving it just enough gas to gradually get into high gear. Your mpgs will be up around 40 or 50 (or more).
Seriously though:
Go fill up with gas. Reset your mpgs and your trip odometer and leave them alone until you fill up again. Drive "normally" for at least 200 miles and fill up again. Divide your miles traveled by the number of gallons it takes to refill your tank and compare that number to what the DIC mpgs reads. They should be pretty close, within 1/2 mpg or so.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 06-23-2013, 10:14 PM   #4
NJ-JRS
C5
NJ-JRS's Avatar
I've been averaging about 23 mpg highway. Last summer I averaged about 29-30mpg on the same highways.
Originally Posted by PalmerGA View Post
You can't go by little short runs, resetting your mpg readout. .
I'm not, this reset was just for purposes of a video. I'm judging from last summer to how it's been overall this summer. It's been something going on for the last couple of months now.
Old 06-23-2013, 11:14 PM   #5
PalmerGA
PalmerGA's Avatar
I see. Hmmmmm. Sounds like a job for the dealership to figure out. MPGs (especially in V6s) usually improves some after a year of so break-in (15K miles or so).
Old 06-24-2013, 06:14 AM   #6
benji1997
benji1997's Avatar
I have 15,000 on mine and the mpg has improved by about 2.
Old 06-24-2013, 07:10 AM   #7
hworth18
Jus' Cruzin
hworth18's Avatar
Drives: 2017 Camaro 1SS Krypton Green
How many miles did you have on the CAI? And why on earth did you re-oil it twice? Sounds to me like you may have too much oil in the filter and it's fouling the mass airflow sensor or restricting airflow into the engine.
I would clean the filter and remove the excess oil, then re-oil the filter per the instructions. Clean the MAF sensor, and also remove the CAI intake tube and wipe out any excess oil that is in the tube, make sure you unplug the battery while you're doing this to reset the ECM. When you get everything back together, reset the mpg on the DIC and take it for a drive. It is also possible that you just have bad gas since the car sat all winter.
My thoughts....
Just a suggestion, you should post this in the LFX section, you'll probably get many more responses there.
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark
hworth18 is offline   Reply With Quote
Old 06-24-2013, 08:17 AM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
I have a CAI inductions intake and glad I do not have oil like a K/N type, as I know the oil can foul the MAF sensor, and that's why other non oil filters are better. Oiling your filter should be done on a so many thousand mile basis like ten thousand to never.............. Never liked oil treated filters and they have given vehicle problems before......And a SS gets 12 mpg in city driving stop and go. and gas has a tendency to loose its oxygen content when sitting and maybe a little trip to the auto parts store for some octane booster is in order if your going to have it sit all winter.............
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 06-24-2013, 09:13 AM   #9
KMPrenger
KMPrenger's Avatar
I would clean the filter and remove the excess oil, then re-oil the filter per the instructions. Clean the MAF sensor, also unplug the battery while you're doing this to reset the ECM. When you get everything back together, reset the mpg on the DIC and take it for a drive. It is also possible that you just have bad gas since the car sat all winter.
My thoughts....
Agree with this. Go buy yourself a can of CRC MAF cleaner. Take her out on the highway and reset it and see what you get.
Old 06-24-2013, 09:16 AM   #10
AKA-22
AKA-22's Avatar
Drives: ELLE-1
something not right .....that should of shot up to 30 plus with rpm less than 2000..
AKA-22 is offline   Reply With Quote
Old 06-24-2013, 10:01 AM   #11
benji1997
benji1997's Avatar
I almost thought that was a Mustang.
Old 06-24-2013, 11:58 AM   #12
NJ-JRS
C5
NJ-JRS's Avatar
Thanks for all the tips guys. To clarify what's already been tried:
-I've 're-charged' the filter twice this summer thinking it may have been too much oil fist time around.
-Used MAF cleaner twice.
-Been using the car the last two months, so have gone through the gas that the car was sitting with and then some.
-My highway mpg has been around 23-25mpg, where as it was 29-30mpg on the same highways last summer.
About 5,000 -6,000.
I meant I did a full recharge twice over the last two months (as in full clean, then oil), suspecting that I might have used too much oil the first time around . Also used MAF sensor cleaner both times. I don't think it could be a gas issue anymore either since I've run through the gas and filled up a handful of times so far this summer.
Yea, I mean if I did the same type of coasting last summer the DLC seemed quicker to acknowledge and easily would have read something 30+. I'm stumped.
Any other troubleshooting tips guys? I don't know how else to troubleshoot this issue other than what I've already done.
Old 06-24-2013, 12:17 PM   #13
hworth18
Jus' Cruzin
hworth18's Avatar
Thanks for clarifying... My only other suggestion would be to take it to the dealership if it's still under warranty.
-Howard Stark
Old 06-24-2013, 01:40 PM   #14
onesimo3
Camaro Enthusiast
Drives: 2013 Silver Camaro 2LT/RS
Are you sure that happens in a short city drive?
With my V6 i get around 17-18 City Driving.
I took it on a long trip. Made 320 miles with half a tank (33 MPG more or less), awesome MPG in highway.
onesimo3 is offline   Reply With Quote
