Old 06-23-2013, 10:50 PM   #1
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Stage 8 locking header bolts
Any good? I thought they were the cats ass but after searching I am not sure. The guy I bought my headers from hooked me up with some brand new ones in the box and I am tempted to use them or sell them and buy the ARP bolts or studs.
L99 With a Maggie
Nutro is offline   Reply With Quote
Old 06-23-2013, 11:06 PM   #2
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
I really like them used them on my 69, same with header to exhaust flange bolts.
Worked really good little anti sieze and you are golden.
BigBlock69RS is offline   Reply With Quote
Old 06-23-2013, 11:11 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You know what i'd suggest you do but i'll make it easy for you JUST THIS ONE TIME.
http://www.camaro5.com/forums/showth...g+header+bolts
FWIW, I used your exact title header in the search box.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-23-2013, 11:37 PM   #4
Nutro
Nutro's Avatar
Yep I did search, as I mentioned, silly.
I just didn't want to base a decision off of one thread where 2 people said they liked them, 2 people didn't and 2 people said stockers were fine
L99 With a Maggie
Old 06-24-2013, 12:52 AM   #5
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Haha, my thread is useful! I acually just ended up going with my OEM.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 06-24-2013, 09:40 AM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^lol yup I've had the same OEM bolts on my fourth gen since 2001 with an Ls1 now it's got an Ls3 with the same bolts lol. They have never backed off either. Lol
Old 06-24-2013, 12:11 PM   #7
2012-2SS
2012-2SS's Avatar
Drives: 2012 Camaro 2SS/RS
OEM bolts work fine but if you have them you might as well use them.
Sent from my Galaxy S3
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms Clear Image headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 5speed
2000 Chevy Tahoe LT 5.3L, Slowhawk tune
2012-2SS is offline   Reply With Quote
Old 06-24-2013, 01:11 PM   #8
axis
Search Ninja
axis's Avatar
No matter what the people suggested, I think that thread does have some very useful info in it. Either will work fine and hold well. If you're wanting the looks, they are a good option along with ARP studs. If you're just wanting something that won't back out, stockers are fine. There is the hassle issue to take into account.
Halltech CF 102 fed
Old 06-24-2013, 01:35 PM   #9
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
I have used studs in the past and Stage 8 header bolts, on my old-school Cutlass that had a SBC in it. The studs worked well but I continued to have issues. The Stage 8 ended the problem and I had none come loose and lost no gaskets for the last 8 years or so that I owned the car. I can say they were not a great grade of stainless, though. They eventually corroded.
chef-beavis is offline   Reply With Quote
Old 06-24-2013, 02:11 PM   #10
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
Use the OEM bolts, sell the Stage 8s, and put the $$ towards something else. Torque them down to the proper spec, check them after a few heat/cool cycles, and you will be just fine.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 06-24-2013, 06:20 PM   #11
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
I have always been 50/50 on them. In my experience they take 3x as long to put on than normal bolts and are a pain to get off if you need to. The main advantage over standard bolts is that you do not have to go back and tighten the bolts later after the car has heat cycled some. Normally the standard bolts only have to be retightened ones, so it really comes down to your preference.
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
* CURRENT SALES * ORDER TERMS * DISCOUNT POLICY
MarylandSpeed is offline   Reply With Quote
