JDP Motorsports
Old 06-23-2013, 11:26 PM   #1
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
Interesting Discovery - FE4 Suspension on a '12 Convertable...
Switched from LG 35mm sways to Pedders ZL type sways over the weekend and found out that I actually have the FE4 suspension on my 2012 vert. It was my impression that all verts 12 and prior had FE3...
Falundir is offline   Reply With Quote
Old 06-24-2013, 06:45 AM   #2
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Really depends on your build date. Mine is an early '12, has the FE3 suspension. But the rear arms have the mounting points for the later sway bars.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 06-26-2013, 05:41 AM   #3
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
I have a 3/13 build date, but my rear arms have the sway bar mounts to the inside. What does the FE4 suspension have over the FE3?
SS PANTHER is offline   Reply With Quote
