Old 06-23-2013, 11:28 PM   #1
sakipat
sakipat's Avatar
Drives: 2010 Camaro 2SS RS
Question PLEASE advise ( unnusual sounds )
I'll try and make this short...
I had some parts put in my LS3 about a month ago...
- Intake
- LT Headers
- Exhaust System
I never had a "modded" car before so I didn't know what to expect (other than reading threads here).
So, here are the 2 unusual sounds I've been noticing:
1. When the engine is cold, car sounds like a "fart can" when accelerating ( around 3-4 rpms )
2. When slowing down from a 30-40mph cruise, I hear popping sounds around the exhaust area.. 2 pops.... pause.. then another 2. and so on....
However, when the engine warms up, all is well.
Please Advise. Thank you.
sakipat is offline   Reply With Quote
Old 06-23-2013, 11:32 PM   #2
Supercharged SS
Drives: 2010 Camaro
- Intake
- LT Headers
- Exhaust System
The slowing down noise is decel popping. You can search about it. Many cars have it. I believe it can be tuned out.
The fart can explanation I have no idea what you're trying to explain. Sorry.
Old 06-24-2013, 02:14 AM   #3
sakipat
sakipat's Avatar
Thank you. I'll record audio tomorrow and post.
Old 02-22-2014, 12:02 PM   #4
txgoose
txgoose's Avatar
Drives: 2010 VR 2SS/RS
This appears to be an old thread, but I too have an unusual sound coming from the back of my car. Seems to be "timed". About 5 minutes after I start my car, I get 5 taps in succession that seem to come from the trunk. No indications that anything is wrong, just "tap,tap,tap,tap,tap". They're faint enough that if I have any throttle going on, I can't hear them, but at a light they're quite noticeable.
txgoose is offline   Reply With Quote
Old 02-22-2014, 12:07 PM   #5
banter
banter's Avatar
Drives: 2016 Camaro 2SS M6 Black
My '07 Cobalt did the same thing and I never figured out wtf it was. People would always joke and ask if someone was locked in my trunk. Haven't heard it from my Camaro though.
banter is offline   Reply With Quote
Old 02-22-2014, 12:17 PM   #6
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
Its your exhaust. As it warms up the medal expands and make those noises. Since the pipes are all welded I would think its the mufflers. Should be nothing to worry about.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 02-22-2014, 05:28 PM   #7
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Do you have an automatic? Could be AFM.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 02-22-2014, 05:44 PM   #8
stevey_frac
Drives: 2010 LT2/RS Coupe
What you are hearing is the evap solenoid going through it's test cycle to make sure it still works. It's normal. Louder on some cars then others.
Mods so far:
MRTv2 Exhaust
275 / 40 / 20 Continental ExtremeContact DW's on all corners
Next up:
Magnaflow Resonated X-Pipe (Purchased but not installed)
EBC Redstuff street pads
Carbotech XP8 / XP12 track pads
1LE Track Pack
Note: This car built by JDP Motorsports!
stevey_frac is offline   Reply With Quote
Old 02-22-2014, 05:50 PM   #9
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
On my 2009 Cobalt SS, when I installed the CAI, on cold start up it was loud.
Dimitrim is offline   Reply With Quote
Old 02-22-2014, 11:38 PM   #10
j3ff9ack
j3ff9ack's Avatar
Drives: '10 RS/SS M6 RJT
Sounds like the fuel system
http://www.camaro5.com/forums/showth...ferrerid=24831
j3ff9ack is offline   Reply With Quote
Old 02-23-2014, 12:04 AM   #11
TigerFA
TigerFA's Avatar
Drives: Camaro 2SS 2014
even get it with the NPP, like it
TigerFA is offline   Reply With Quote
