Old 06-23-2013, 11:34 PM   #1
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
spark plug on #4 cylider looks bad... why?
I was changing my spark plugs today to the LS7/LS9 plugs (AC Delco 104's).
When I was removing the stock plugs I noticed excessive wear on the spark plug in the #4 cylinder. Like so:
Top = new 104 plug
Middle = old 110 plugs (this one looks similar to the ones from all other cylinders)
Bottom = old 110 plug from cylinder #4 (I am guessing that a .087 gap is bad)
What is causing this?
Info about my car:
-about 140,000 total miles, about 70K of those are on the cam in my sig (all on the same 110 plugs)
-no CEL because of misfire
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-23-2013, 11:36 PM   #2
SPCBA
Drives: pleather and Chiclets
looks like the tip failed and it just snowballed. dont see any ash on it just excessive soot
SPCBA is offline   Reply With Quote
Old 06-23-2013, 11:42 PM   #3
Bell040
Bell040's Avatar
So .... nothing to worry about?
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-23-2013, 11:46 PM   #4
BLACK10
BLACK10's Avatar
that doesnt look ok to me.........
Old 06-24-2013, 12:21 AM   #5
Bell040
Bell040's Avatar
That's what I was thinking, but what is not okay?
Will the new plug fix the problem? ... or is it possible that something is wrong with that cylinder system (injector, valve, leak, etc)?
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-24-2013, 12:26 AM   #6
BLACK10
BLACK10's Avatar
hard to tell from a pic, but looks really black. so how many miles on that plug?
Old 06-24-2013, 12:36 AM   #7
Bell040
Bell040's Avatar
140,000
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-24-2013, 01:09 AM   #8
SPCBA
i would be really worried. i would check my plugs everyday and take it to my tuner. my tuner wouldnt be ok with it either. something went wrong. hope its a bad plug.
Old 06-24-2013, 05:46 AM   #9
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Could be some detonation caused that tip to fail sometime along the way, but 140k on a set of plugs? Sheesh. Who knows if or when.
Iam Broke is offline   Reply With Quote
Old 06-24-2013, 06:41 AM   #10
Craig B
Craig B's Avatar
Drives: 2013 1LE
Looks like #4 may be taking on some oil? Could be why the tip is missing, from detonation.
Craig B is offline   Reply With Quote
Old 06-24-2013, 11:40 AM   #11
Bell040
Bell040's Avatar
I can pull #4 every week or so to check. Every day is not feasible, as life still happens. It is too bad that #4 is by far the hardest plug to pull.
I had them out at ~70K (during cam swap) and they were fine.
I guess there is no way to check this? ... without pulling the heads anyway
Question is... why was there no CEL due to misfire?
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-24-2013, 11:57 AM   #12
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Oil won't make the tip wear away like that. But with 140k, hard to say what's happened there. To me in looks like the ceramic is gone, and that usually happens to to an ultra-lean condition (bad/plugged injector), detonation, or the plug got really hot for some reason.
You don't mention any other underlying symptoms, but I would at the very least run a compression check to make sure all is even. If it's okay, put in your new plugs and see how it runs. If it runs okay, give it some hard pulls and take out #4 and another plug for comparison. If all looks good, put it back together and check that plug occasionally for any abnormalities.
Bye bye, Bumblebee!
Old 06-24-2013, 12:04 PM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
So you've ran a spark plug for a total of 140k miles? Or 70k after the cam?
Either way that's crazy intervals. Your lucky the others don't look the same way.
Old 06-24-2013, 12:20 PM   #14
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Is that header tube the same color as the rest?
Southern Comfort is offline   Reply With Quote
