Old 06-24-2013, 12:05 AM   #1
kenkartasasmita
COTW [4/23/12]
kenkartasasmita's Avatar
Drives: Camaro Of The Week.
v6 brakes swap to ss ?
so im buying a ss brakes from a member, is it just the rotors and calipers all i need to do the swap ? do i need the brake lines and other thing? please someone educate me.
Originally Posted by Nightfall View Post
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession
2010 Camaro V6 1LT | Kooks Catback Exhaust + MBRP exhaust tips | TF3 Stripes | GM Transformers Emblem and Door Sill | Stillen splitter | GMX rear diffuser | K&N CAI | Pulstar iridium spark plugs. | Gm High Wing Spoiler | BBK LT Headers | BMR 4 Point Strut Bar | BMR 1" Lowering Springs | ZL1 Side Skirt | Black Ice-olator | Trifecta Tune |
My Build Thread
kenkartasasmita is offline   Reply With Quote
Old 06-24-2013, 12:31 AM   #2
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
I'm pretty sure it is just the rotors that need replacing. The stock brake lines should be fine to use
Aubrey64 is offline   Reply With Quote
Old 06-24-2013, 12:48 AM   #3
kenkartasasmita
COTW [4/23/12]
and the calipers too right? that's all i need?
My Build Thread
Old 06-24-2013, 01:16 AM   #4
Aubrey64
Aubrey64's Avatar
As far as I know yes!
Old 06-24-2013, 01:19 AM   #5
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
The rear ss rotors are app 1-2 inches bigger than the v6's so you can either replace the v6 dust shields (which is a PITA) or trim them by 5/8"
But I would recommend getting ss lines personally...
Lil' Nasty is offline   Reply With Quote
Old 06-24-2013, 01:28 AM   #6
kenkartasasmita
COTW [4/23/12]
thanks man.
they are bigger. yes... educate me a bit please, i dont get what u mean. what's is PITA, and do you mean cut the dust shield by 5/8?
My Build Thread
Old 06-24-2013, 01:39 AM   #7
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
thanks man.
It's a pain in the ass to remove and replace the stock v6 dust shields so I would, if I were you trim your rear dust shields by 5/8" of an inch to make the rotors fit.
This thread should help
http://www.camaro5.com/forums/showthread.php?t=62282
Old 06-24-2013, 03:24 AM   #8
kenkartasasmita
COTW [4/23/12]
ohhh okok. i get it now. thanks for the help.
My Build Thread
Old 06-24-2013, 01:47 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
I suggest adding on a set of stainless steel brake lines as well. Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 06-24-2013, 01:54 PM   #10
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
I would change the break lines also. So you would need Calipers, Rotors, Pads, and Break Lines. Like Lil' Nasty Stated the rear dust shields will need to be trimmed down to clear the rotors and it should be a straight forward install. Also depending on how many miles you have I would consider a break fluid change.
Proud owner of litho #179 Click Picture for Build Thread
Old 06-25-2013, 10:46 PM   #11
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
You will need the ss lines due to the ss line being longer than the v6 lines, good time to go to stainless lines if money is there to blow, but like others have said rotors, calipers, hoses and youll be ready to bleed some brakes
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is online now   Reply With Quote
Old 06-30-2013, 03:19 PM   #12
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
Best regards,
Tyler
888-308-6007
jesus sales guys are hardcore smell blood and there on it...Hah!
firestone_ss is offline   Reply With Quote
