sjm autoprod
Old 06-24-2013, 02:39 PM   #1
VICREDSS
Drives: 2013 victory red 2SS/RS
ricks camaros Axle Back
Anyone have any insight or have these on there car. I am looking for an axle back exhaust and came across these for $299. Just want to see if there worth it or not thanks!!
VICREDSS is offline   Reply With Quote
Old 06-24-2013, 02:54 PM   #2
Del's12SS
Del's12SS's Avatar
Drives: 2012 Camaro SS/RS Convertible
Might want to check out the V8 bolt on section.
Del's12SS is offline   Reply With Quote
Old 06-24-2013, 03:02 PM   #3
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Ive never heard of it, which means it wont end up being one of the suggestions if you ask people in the bolt on section.
Stainless works retro chambered, SOLO, borla, corsa, are all popular on C5.
What kind of sound (volume and tone) do you want to end up with?
Old 06-24-2013, 03:25 PM   #4
VICREDSS
Thanks guys I'm just debating on going to my local exhaust shop because a lot of the axle backs are 500+ dollars! I'm finding online.
Old 06-24-2013, 03:31 PM   #5
1EvilLE
1EvilLE's Avatar
Drives: 2013 Camaro 1LE
Pypes Axle Back
Pypes Performance axle back from Summit is $266 - $300 black ones. Love the sound great quality!
1EvilLE is offline   Reply With Quote
Old 06-24-2013, 03:57 PM   #6
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
You need to plan ahead for what type of sound you eventually want.
You may regret a loud axleback later on if you delete you get headers, cats, x pipe, etc.
Old 06-24-2013, 04:22 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
$500 may sound like a lot for just a axleback but stop and think about what you're getting. Many of the good mufflers are $100-$150 each and nice tips, especially double walled, can run $50-$100+/each as well. Add in piping and getting the hangars welded on to make the mufflers sit just right, and you're up in the $500 range. Axlebacks can easily be installed in your garage with a set of jackstands and a sawzaw or hacksaw so no shop labor charges. There are many axlebacks that are cheaper than $500 though.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-24-2013, 04:23 PM   #8
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Right. My SOLO was 400 i think
Old 06-24-2013, 04:28 PM   #9
axis
Search Ninja
axis's Avatar
Solo's typically come with some nice tips as well. Many people don't realize just how expensive a set of nice tips can be.
Halltech CF 102 fed
Old 06-24-2013, 04:46 PM   #10
VICREDSS
Thanks everyone for the responses. And thinking about it your right with the nice tips and hangers and having everything come ready to go is worth it, I'm going to shop around does anybody have any recommendations, I have the factory ground effects so I'm finding its more limited because not all axle backs fit with the ground effects.
Old 06-24-2013, 05:47 PM   #11
bkdamon
bkdamon's Avatar
Drives: Rally Yellow 2012 1LT
All true but getting the clamps tight enough is not altogether easy. Many end up having to pay for a spot weld as a minimum. Just saying you need to factor that in to the total cost.
bkdamon is offline   Reply With Quote
Old 06-24-2013, 06:13 PM   #12
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Quality sets come with quality clamps, modern systems are precise enough that you dont need to weld anymore.
The entire factory system isnt welded. Trust me, you dont need any welding done for a quality axleback or cat back, or headers, or high flow cats
Old 06-24-2013, 06:18 PM   #13
bkdamon
bkdamon's Avatar
Might be I need an impact wrench then but the MRT axlebacks definitely keep rotating. Don't know what that says about the quality.
Old 06-24-2013, 07:39 PM   #14
converted
Drives: 2012 45th anniversary
Plus 1 for this set up! I have them on my ls3 and other than having to add jpipes to kill off a little drone at 70 they are terrific!!
converted is offline   Reply With Quote
