Old 06-24-2013, 04:37 PM   #1
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Tire pressures
I'm on the road course (NJMP)Thursday&Friday with my new 1LE tire/wheel package.Any suggestions for tire pressures at the track?
rockrau is offline   Reply With Quote
Old 06-24-2013, 05:03 PM   #2
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
32
cornerspeed92 is offline   Reply With Quote
Old 06-24-2013, 05:20 PM   #3
5.3Avalanche
Drives: '08 Silverado, '99 T/A WS6
As a rule of thumb in my T/A:
If you run nitrogen I'd run mid to high 30's or low 30's if you run regular air. With regular air, the moisture content expands and contracts to a higher degree with a change in temperature. Pure nitrogen is essentially dry so it doesn't have this effect.
That's been my experience though. The F1 tires on the 1LE are probably much stiffer than what I'm used to so low 30's may be okay. Best to take it to the track and adjust it as you go to see what works. The track temp will also affect what amount of pressure that works best.
'08 Silverado | GMPP Exhaust | Z60 Suspension
'99 Trans AM | Magnaflow Exhaust | WS6 Performance Package
5.3Avalanche is offline   Reply With Quote
