HeadlightArmor
Old 06-24-2013, 04:52 PM   #1
Bradanomics
Drives: 2013 2LT vert
C5 Install
Hey I have some JL C5s that I want to put in the front of the car. Where can I get the...converter to change the hole size and will the tweets fit inside the stock tweeter position? I have the Boston system in there now. Also, how do I mount the crossover box?
THanks
Bradanomics is offline   Reply With Quote
Old 06-24-2013, 05:40 PM   #2
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
I put JL C2's in mine. I don't know what converter your talking about for the tweeters. I wrapped mine in 3m tape and put the back in the same spot. Worked well. Here's we're I mounted my crossover. I didn't want it inside the door, with the chance of getting wet. Plenty of room behind the door panel there.
Old 06-24-2013, 05:59 PM   #3
Bradanomics
I mean when I'm mounting the woofer. Does it just fit right in the hole?
Old 06-24-2013, 06:42 PM   #4
Twilborne
Twilborne's Avatar
Drives: 2013 Blue Ray Blue 2LT
You will need speaker adaptors... metra or ********. Metra is plastic and ********'s are wood. I opted for the metra... Twetter's should fit in the factory pods.
Twilborne is offline   Reply With Quote
Old 07-11-2013, 09:02 PM   #5
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
How'd you wire those c2's up? They look like a good deal at $135 on amazon.
How do they sound?
I listened to the c3 and they sound crisper and the c5 sounds warmer.
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
Old 07-11-2013, 09:06 PM   #6
vtxretro02
vtxretro02's Avatar
Drives: 2012 Camaro 2ss Heritage Grill/GFX
jl c5 650's
I have c5's in the door pushed by a xd400/4 and a stealthbox pushed by a xd 600/1 stock rear deck speakers... it kicks and sounds great...
vtxretro02 is offline   Reply With Quote
Old 07-11-2013, 09:50 PM   #7
Camaroshark
I just put the XD 400/4 in to replace the BA amp... I am also running a ******** stealth box kicker 12 with the kicker zx 400 amp. All of it rocks.
I am considering a change on the door speakers
Old 07-12-2013, 02:18 PM   #8
Chris-10
Chris-10's Avatar
How do they sound?
If your talking about how to wire the crossover up its easy. Take the factory speaker wire to the crossover then run a separate wire to the woofer and then Another to the tweeter both from the crossover.
They sound real good! I couldn't be happier!
Old 07-13-2013, 11:35 PM   #9
ALLHAILFRANKOS
ALLHAILFRANKOS's Avatar
Drives: 2010 Camaro 2SS/RS M6 IOM
I also ordered the Metra front door speaker adapter for my C2650 components. I just noticed they state the adapter is for 6 inch components. Will the adapter work or no?
ALLHAILFRANKOS is offline   Reply With Quote
Old 07-14-2013, 07:24 AM   #10
Twilborne
Twilborne's Avatar
Yes they will work just fine.
