Cold Air Inductions
Old 06-24-2013, 07:01 PM   #1
Twoblindsheep
[COTW 1/6/14]
Twoblindsheep's Avatar
Drives: 2017 1LE
People with Metra Kit.. HELP!
hey guys.. i have the metra kit and im having some issues i cant fix.. first of all.. my AC dont work.. the only way to get them to work is if i hold them down and it will turn up.. my heated seats also dont work oh and my rear defrost..
another big thing... my parking sensor dont work anymore.. i was told by the shop that when you install the kit.. the parking sensor wont work..is that true?
because when i put it in R it also no longer beeps.
help me out guys.. this is making me crazy! lol
ERL 416ci, Landspeed Stg 3 heads, CAI intake, ported FAST LSXR, NW 102TB, custom grind cam, LG long tube, Solo J pipes. 518rwhp/507tq
Twoblindsheep is offline   Reply With Quote
Old 06-24-2013, 07:29 PM   #2
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
try to find out what software version you have on it and if all wires are connected
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 06-24-2013, 07:36 PM   #3
poohdogger
Drives: 2011 1ss black on black 6m
That should be a software issue.......
poohdogger is offline   Reply With Quote
Old 06-24-2013, 08:21 PM   #4
Twoblindsheep
[COTW 1/6/14]
Drives: 2017 1LE
well it was installed by a sound shop.. and how do i check for the software? they told me they re flashed it and it was still doing the same thing
Old 06-25-2013, 05:39 AM   #5
Twoblindsheep
[COTW 1/6/14]
Drives: 2017 1LE
Old 06-25-2013, 11:33 AM   #6
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
Well that is not true.. My parking sensors all work.. and the AC and all other controls work as well.. First, make sure that the Pink cable is connected to both end. That cable comes from the connectors that goes to the car adaptor and connects to the pink cable on the face plate of the metra kit. If that is correctly connected. U need yo remove the Axxis interface. Get a mini USB cable or adapter and connected to your PC. Go to Axxis.com or whatever there website is and find their update software. Download to PC and that will check on your software on ur module and tell you if you need and upgrade. it will downloead it and install.. Most likely it is that that is causing the issues.. On the other hand, I have similar issues with the AC controls.. I did all that ad also return to the stock face just for the AC controls to turn them all the way down and up.. Then reconnected Metra and its all good
Wuiquen is offline   Reply With Quote
