Old 06-24-2013, 08:20 PM   #1
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Belt dust on top of supercharger
I don't know much about belt alignment or anything. I'm getting rubber dust on the top of my vortech ysi v7 (self installed, no shops nearby.) It's dusting right after the tensioner near the supercharger pulley. What do I need to adjust?
K32 Camaro is offline   Reply With Quote
Old 06-24-2013, 08:24 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Tensioner probably isn't adjusted tight enough so your slipping your belt when you get on it.
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 06-24-2013, 09:02 PM   #3
K32 Camaro
V8 lounge member #5
I doubt that. i had to have the idler off and tensioner pulled all the way back to even get the belt on..
Old 06-24-2013, 09:08 PM   #4
ToddB
Drives: 2011 2SS Convertible Supercharged
I had belt dust on mine until I tightened it up as tight as I could get it. Also a new belt will stretch a lot the first 100 miles or so.
2011 Camaro SS, LS3,Whipple SC, 13 PSI,CAI intake, ARH 2" Headers, Corsa exhaust, ZL1 fuel pump with ADM FPCM LS9 Cam and Meth,ID850, BMR suspension upgrades,Tune by JRE
ToddB is offline   Reply With Quote
Old 06-24-2013, 09:58 PM   #5
Slickcas
Drives: 12' 2SS/RS LS3 IBM
I have the V3 so it's a little different. But when I pulleyed down I changed the location of the tensioner and routed the belt under the idler. It gives a little more belt wrap around the blower pully. Vortech allready had the holes in the brackets. I picked up a bold from Fastenal the odd thing is the bolts going into the Vortech brackets are metric and the bolts going in to the blower are standerd. I am at work so I do not have a pic to post righ now.
Slickcas is offline   Reply With Quote
Old 06-24-2013, 10:08 PM   #6
blake-b
blake-b's Avatar
Drives: Black 2010
My cog belt also dusts the pulley.
Old 06-25-2013, 01:24 AM   #7
K32 Camaro
V8 lounge member #5
It seems the tensioner comes out by almost 1/16th. Is that normal as well? (Towards the front of the car.)
Old 06-25-2013, 01:41 AM   #8
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
How is your belt routed? I routed my YSI like Ted suggests and haven't had any wear on the belt.
DarkCry956 is offline   Reply With Quote
Old 06-25-2013, 02:01 AM   #9
K32 Camaro
V8 lounge member #5
I didn't know he had a different routing. Haven't gotten the upgrade from him yet. It goes from crank to s/c with the tensioner on it top side 3/4 from the left and the idler bottom side 1/4 from the left.
Old 06-25-2013, 12:36 PM   #10
K32 Camaro
V8 lounge member #5
Bump
Old 06-25-2013, 12:47 PM   #11
Unreal
Drives: 2006 Z06
A little dust is normal on a fresh belt. If it keeps doing it than it is too loose.
Nick
Corvette Z06 -1200ish rwhp
Old 06-25-2013, 12:57 PM   #12
BLACK10
BLACK10's Avatar
can you post a pic?
Old 06-25-2013, 01:09 PM   #13
K32 Camaro
V8 lounge member #5
I have 3 on their way. Will take a couple minutes though.
Old 06-25-2013, 01:17 PM   #14
DarkCry956
DarkCry956's Avatar
I have mine routed under the idler pulley not over like Vortech has a on the instructions. I changed pulleys too so I dropped the tensioner to the bottom position.
