BeckyD @ James Martin Chevy
Old 06-26-2013, 12:37 PM   #15
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
Are those numbers corrected or actual?
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 06-26-2013, 01:06 PM   #16
ls7camaro
Drives: 2010 camaro
Only 22 more hp and it will be the most hp that engines made.
ls7camaro is offline   Reply With Quote
Old 06-26-2013, 01:58 PM   #17
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
Pretty sure that is SAE.
Good luck with the build Jeremy... Hope you get this sorted out soon, I just don't know why the numbers seem so low.
AngelSpeedFreak is offline   Reply With Quote
Old 06-26-2013, 02:03 PM   #18
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
do me a favor. throw the stock 45th wheels on and do the dyno pull again. I want to pretend it is mine!
2012 45th L99 SS-Cold air inductions CAI-Dynatech LT's-Solo mach XL catback
333hp/341tq (before LT's)
steveo9043 is offline   Reply With Quote
Old 06-26-2013, 02:10 PM   #19
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
lol steveo
Hey jeremy, what kind of IAT's are you seeing?
xjer22x is offline   Reply With Quote
Old 06-26-2013, 03:45 PM   #20
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Sure thing!
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 06-26-2013, 04:15 PM   #21
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Originally Posted by 2SS45th View Post
Hit the dyno today with updated tuning, and got some better numbers this time. Best run was 621rwhp and 688rwtq, boost went up from 13ish to 16.4psi and had zero belt slip. Much happier with the results this time, and no limp mode
Don't make fun of my 621whp, it's mighty
You are scaring me away from the 416 ci displacement in a serious way as I to have the Maggie SC. I am thinking it would be much wiser for me to stick with stock cubes so I can get boost numbers up. Its hard to believe your pushing 16.4 lbs of boost and only at 621 rwhp.
I would have thought you would be well over 700 at that boost level........ Hope you find your lost ponies soon, they have to be hiding in there somwhere!!!
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 06-26-2013, 05:19 PM   #22
2SS45th
2SS45th's Avatar
I am losing 50hp just to my lower compression right off the bat. Then you factor in that I don't have the spacer or some of the other little tricks and it starts to make sense. I figure with nitrous and all the tricks I could hit 900 to the tire.
Old 06-26-2013, 05:49 PM   #23
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
A Maggie on a 416 isn't the greatest idea anyway. If you want more cubes fiftydriver get a bigger blower that will be more efficient on it.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 06-26-2013, 05:53 PM   #24
Fiftydriver
Ya I know, my car is a 100% street ride so I love the low end grunt of the TVS2300 and as my car will run in the idle to 4500 rpm range for 90% of its life on the street I will be happy if I can get 650 rwhp.
I have been told this is practical with the Maggie and a properly set up 376 but anything more and its better to go larger displacement.
Just really do not want to put another $7000-$9000 into another supercharger kit as I already have the Maggie and want to try to work with it if possilbe. Just is looking like stock cubes are the wisest direction to go with the Maggie.
Fiftydriver
More to come!!
Old 06-26-2013, 06:30 PM   #25
epstein
Drives: SS/RS
Send a message via AIM to epstein
Hello Hes In Colorado...... Anyone ever try run 100 yards in Colorado air?
Hes getting killed
epstein is offline   Reply With Quote
Old 06-26-2013, 06:35 PM   #26
Supercharged SS
Drives: 2010 Camaro
You'll never see 900 unless you spray a 200 shot. You're already at 16.4 psi. Much more and it's out if its efficiency range and becomes counter productive.
Accept that or change to a bigger blower.
Old 06-26-2013, 06:36 PM   #27
Supercharged SS
Drives: 2010 Camaro
Forge your engine. Especially if you just want a stout street ride.
Old 06-26-2013, 10:03 PM   #28
2SS45th
2SS45th's Avatar
Yeah, I was gonna direct port it and spray it to the moon!
