Old 06-25-2013, 03:28 AM   #1
RS117
RS117's Avatar
Drives: 2011 2LT/RS
How much fuel to have in the tank when drag racing?
How much gas to have in your tank when drag racing?
Well I tried doing some research, and got varied answers. Some say have as low as you can, about 1/4 to decrease weight, while others said 3/4-1/2 because the fuel weight is right over the rear tires, which will help you gain traction.
Considering the Camaro already has more than enough weight, what do you guys think, the less weight the better? I tried both at the track. One time I was at 1/4 tank, and another I was at 3/4 tank. Did not notice a huge difference. Common sense tells me the less weight the better, but this what I found. (1/8 Mile). Car is completely stock.
1/4 Tank: 60' was 2.15 with a time of 9.52 (Tire pressure was about 34)
3/4 Tank: 60' was 2.20 with a time of 9.74 (Was a bit warmer temp, tire press about 32, and had a passenger)
I know many more variables are to be considered, so what do you guys think?
RS117 is offline   Reply With Quote
Old 06-25-2013, 09:16 AM   #2
Merc
In The Circle
Merc's Avatar
1/4 tank or less.
Old 06-25-2013, 09:20 AM   #3
Supercharged SS
Drives: 2010 Camaro
So full it's about to puke out of the filler.
Old 06-25-2013, 09:33 AM   #4
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
HUH?!??!
why?
thats like 100 extra lbs..
on vapor.. then put 2 gallons of race fuel at the track..
thats all you need.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 06-25-2013, 09:45 AM   #5
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
race fuel is a waste of money, unless you have a tune for it...
Old 06-25-2013, 09:56 AM   #6
JEFF75645
Drives: his wife crazy buying mods
When I do go to the track I usually run with 1/8 of a tank. And fill as needed.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 06-25-2013, 09:57 AM   #7
DuskSS
DuskSS's Avatar
Of course we are tuned and heavily modded.. Dope or Boost..( or both) not stock cars. 600-1500+ hp cars down here.
530/520 SAE
Old 06-25-2013, 10:15 AM   #8
Supercharged SS
Drives: 2010 Camaro
Originally Posted by DuskSS View Post
HUH?!??!
why?
thats all you need.
Traction. Spins out of control with anything less. Part of the reason my cars race weight is 4217 lbs.
I fill the entire tank with 104. It's about $250.
Old 06-25-2013, 12:16 PM   #9
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Respectully, Jamie you need adjustable drag shocks and need to play with a 2 step, got to pull out weight sir.
I run 1/4 tank if I can time it right, but sometimes it's 1/2 tank.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-25-2013, 12:39 PM   #10
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
If I remember correctly, fuel weighs around 6 lbs per gallon....so approximately...
20 gal (full) = 120 lbs
5 gal (1/4 tank)= 30 lbs
90 pounds less with 1/4 tank....that's how I'd roll....lol...
90503 is offline   Reply With Quote
Old 06-25-2013, 12:45 PM   #11
Ice Demon
Ice Demon's Avatar
Drives: 2010 Camaro SS
Originally Posted by Merc View Post
1/4 tank or less.
Mods: "Cam Only"
Ice Demon is offline   Reply With Quote
Old 06-25-2013, 12:51 PM   #12
blufin
blufin's Avatar
Drives: Fire Engine
I usually start the night at 1/2 and finish around 1/4.
I think it's funny when people give Jamie racing tips. j/k
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 06-25-2013, 12:56 PM   #13
Supercharged SS
Drives: 2010 Camaro
I have the Pfadt drag specific shocks so we are working with that. Limited track time this year is killing the progress. Only two trips so far.
Couple more trips and ill get it dialed in. Hopefully before camaro fest.
No two step. I leave off idle. Maybe 1000 if I'm feeling crazy. Any higher and no traction.
Def no weight reduction. I race it the way I drive it in the street. Just swap tires.
Old 06-25-2013, 12:57 PM   #14
Supercharged SS
Drives: 2010 Camaro
Ill loose more than .1 blowing the tires off.
Just think, I also have a 5 gallon ice cell in the trunk as well!!
