Old 06-25-2013, 01:11 PM   #1
BUMBLEBEE_SS
BUMBLEBEE_SS's Avatar
Drives: 2010 SS LS3 S200 56/61 AGP TT
Cam install and supporting mods
What supporting mods would you recommend for a custom cam.
I know springs and valves timing chain and tune, what about lifters? Injectors? Spark plugs?
I will be doing a super charger or twin turbos. Will this have an effect on the cam down the road? Want to go in once and do it right.
Thanks guys! A month away from this!!!
BUMBLEBEE_SS is offline   Reply With Quote
Old 06-25-2013, 01:16 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Forced induction will certainly need a camshaft designed for it, otherwise the combo not be optimum. Headers are a must on a naturally aspirated car, even good to do on a supercharged car. The lifters on the ls3 are good, the afm lifters (8 of them) on the auto cars need replaced with ls3 lifters.
On the spark plugs, its going to depend on the setup, most cammed cars will like a little cooler plug. The only real way to know is to make a good long pull on the dyno and shut down, inspect plug. The wideband and datalog will show you a general idea of what the motor wants, reading the plugs is the best way to tune it though. And it will also tell you if the plug is too hot or too cool.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-25-2013, 01:27 PM   #3
Blackkaz04
Drives: In the market
search...cam...
Blackkaz04 is offline   Reply With Quote
Old 06-25-2013, 01:31 PM   #4
BUMBLEBEE_SS
Okay good to know.
Old 06-25-2013, 02:59 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Are you an Ls3 or L99?
Old 06-25-2013, 04:55 PM   #6
BUMBLEBEE_SS
LS3. My speed shop today said they can put in a blower cam and it will effect driveability a little bit.
they said TT would need a new cam but the supercharger would be fine.
they said they'd only put in a new timing chain and springs and the rest was fine.
800 for cam and springs 1000 labour and 700 for tune
Old 06-25-2013, 05:51 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What shop is this?
C5r timing chain from katech.
Melling 10296
BTR platinum springs
Ls2 chain dampner (to replace the current chain tensioner because IT SUCKS)
800 for a cam? Jeeeez
700 for a tune?
Old 06-25-2013, 09:34 PM   #8
BUMBLEBEE_SS
Moretto in Edmonton AB Canada
800 for cam and springs.
Is this expensive?
Old 06-25-2013, 10:17 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What springs?
Old 06-26-2013, 10:36 AM   #10
BUMBLEBEE_SS
Not to sure about the springs.
But it'll be a blower cam
Old 06-26-2013, 11:52 AM   #11
SPCBA
Drives: pleather and Chiclets
Is this expensive?
dont really know pricing in canada. in us dollars that would be towards the high range just for a cam. good springs and a cam not so much. quality springs arent cheap.
SPCBA is offline   Reply With Quote
Old 06-26-2013, 12:06 PM   #12
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Will your shop let you bring them the parts? It might be cheaper (and better) for you to source your own parts and have them install them. $700 for a tune is pricey down here, but like SPCBA said... I don't know what prices are like up there. Supply and demand.
Litle88 gave you a solid list of parts to upgrade. He forgot the comp trunion upgrade. Other than those parts you just need a cam and a tune. You should be able to get a cam made or bought off the shelf for ~$400. You want the 3-bolt core too.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-26-2013, 12:14 PM   #13
Ivan @ Southwest Speed
Get at us when you're ready. We won't oversell you and we'll offer you the most HP for the $$....
Thanks and good luck in your build!!
Old 06-26-2013, 07:58 PM   #14
BUMBLEBEE_SS
Thanks boys. Ill call tomorrow and ask them!
