Solo Performance
Old 06-25-2013, 05:39 PM   #1
crt013189
Drives: Camaro
Engine Power Reduced P0601
Well my car is at the dealer and the following codes have came up [ECM] P0122 [ECM] P0140 [ECM] P0141 [ECM] P0160 [ECM] P0161 [ECM] P0223 [ECM] P0601 [ECM] P2270 [ECM] P2272 [ECM] P0036 [ECM] P0054 [ECM] P0056 [ECM] P0060
They dealer is telling me they do not want to work on it because the car has headers and that P0601 shows that the PCM has been reprogrammed, it has never been programmed before and the headers have been on for 6 months and this is the first problem I have had from what I can tell looks like there is something wrong with the throttle body, can anyone else concur or help me out here and exactly what is P0601 I know it is internal check-sum error but does anyone have the specific diagnostic tree from GM showing how to fix that code or more specifically what exactly it is, any help here is greatly appreciated. Car is a 2011 LS3 with TSP Headers, Borla Exhaust, and CAI intake.
crt013189 is offline   Reply With Quote
Old 06-25-2013, 05:42 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Where are you located?
Old 06-25-2013, 05:49 PM   #3
crt013189
Drives: Camaro
Chicago the car is at Advantage Chevy in Hodgkins
Old 06-25-2013, 06:05 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
So they are saying that the problem was caused by the tune? Or mods?
Your not far, but unfortunately I'm at work. Who tuned the car bud?
Old 06-25-2013, 06:11 PM   #5
crt013189
Drives: Camaro
Car is not tuned they are saying I tuned the car and that's why they cant touch it I told them to check the counter on the PCM and he really didn't want to so I called GM corporate they are getting involved, just nonsense really. looks like the TB needs to be replaced for sure but GM will be calling me back tomorrow with more info, I was looking into finding out exactly what the code P0601 means because I'm 99.9% sure it doesn't mean I programmed the PCM which is what I was told
Old 06-25-2013, 06:21 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
It could be your TB, ECU Or fuel pump bud.
That's what I'm gathering.
Old 06-26-2013, 10:41 AM   #7
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
P0601 = bad PCM
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-26-2013, 12:01 PM   #8
crt013189
Drives: Camaro
Well tell dealer is trying to blame that on not having the rear O2's connected is that possible
Old 06-26-2013, 12:22 PM   #9
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
You're going to have a VERY tough time trying to get a dealer to do warranty work with no O2 Sensors connected!!!! Tuned or not!!! If you really want to press the issue, remove the headers, put your factory manifolds/cats back on and see if your problems persist. If so....then you can raise hell with the dealership!!!
blazzin1 is offline   Reply With Quote
Old 06-26-2013, 12:25 PM   #10
crt013189
Drives: Camaro
Why should it even matter though dont they have to prove having the rear O2 sensors disconnected is what is causing the problem
Old 06-26-2013, 12:30 PM   #11
blazzin1
blazzin1's Avatar
Well, they can't do that if you don't have your factory manifolds/cats installed!!! They can't connect the rear O2 Sensors, to see if the problem goes away, if they don't have a hole to install them in!!! And, in reality, they really don't have to "PROVE" anything to you. It's kind of like the old "you're innocent until proven guilty" thing. It doesn't always work that way, in many cases YOU need to prove your own innocence. In this case, you'd be better off installing your factory manifolds, cats, and O2 sensors and proving to them that wasn't the problem.
Did you really go for 6 months without any CEL lights on the dash with long tube headers installed and NO tune??? That seems impossible...I'm skeptical. Did you install the headers yourself or have them installed by someone else?
Old 06-26-2013, 12:33 PM   #12
crt013189
Drives: Camaro
Well GM corporate is involved now I am supposed to get a call back today so I will keep this updated with what I hear
Old 06-26-2013, 02:53 PM   #13
Bell040
Bell040's Avatar
There is no way that running with the rear O2s disconnected fried the PCM. I can never understand why dealerships try to push away warranty work because of . It pays the same.
It also leaves a lot of customers displeased... which is even worse.
I would take it to a different dealer.
.... or buy a new PCM, and get it custom tuned since they are denying warranty work anyways.
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-26-2013, 06:15 PM   #14
crt013189
Drives: Camaro
I agree I'm curious to see what they say of how the PCM got fried
