Emblempros
Old 07-01-2009, 09:24 PM   #1
tommygun6644
tommygun6644's Avatar
Drives: 2010 Camaro 2SS/RS & 2006 Cobalt LT
Question for seasoned stick shift drivers
Hey guys,
As of 6/11/09, I became the proud owner of a 2SS/RS IBM Camaro w/ Sunroof and Manual Transmission.
It is my first stick shift car, and I've come a long way in terms of driving it between the 11th and now. I had to have a friend drive it home for me
But I have a few questions that I would appreciate if anyone can answer. It's basically do's and don'ts, more or less...I want to avoid "hurting" my baby as much as I can.
1. As you could probably guess, steep hills are a toughy for a new stick driver (me, anyways). And idiots where I live get right on my ass when I'm on a hill at a stop light or something. So what I have to do so I won't roll and hit the idiot behind me is keep the break depressed and let off the clutch until it hits that "sweet spot" and starts to roll forward without giving it any gas. Is this considered "riding it", and how bad is it for the car? Also, backing up I have been inclined to do this to, since if I give it gas a let off the clutch I will probably go launching into a tree or something ... is this normal?
2. When at a light, do you recommend keeping the clutch depressed or putting it in neutral and letting off the clutch?
Thanks in advance
tommygun6644 is offline   Reply With Quote
Old 07-01-2009, 09:29 PM   #2
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
1. Don't be afraid to use the emergency brake to help hold you in place on a hill until you get the hang of it. Go somewhere where you are by yourself and practice. It will payoff.
2. Don't think it matters. Depends on the length of the light, how long you've be driving, etc, etc. Either way isn't going to hurt the car.
Good luck!
Inspector 17 is offline   Reply With Quote
Old 07-01-2009, 09:30 PM   #3
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Answer #1: No. That's just the clutch grabbing onto the engine power to start moving the car: think of it as the equivalent to the idle speed 5 mph on an automatic car. RIDING the clutch is when you give the car gas while you have the clutch depressed which will wear it out. It's common for folks to ride the clutch if they're trying to do a speedy reverse. It's okay to cheat once in awhile but don't make a habit of it. As for steep hills, if it's working for you right now and your car hasn't blown up yet, then keep doing it.
Answer #2: When you're at a light, just put it in first and keep your foot on the clutch. It's not worth putting in neutral since it's bound to not last too long.
nUcLeArEnVoY is offline   Reply With Quote
Old 07-01-2009, 09:31 PM   #4
onechuck
Onechuck
onechuck's Avatar
Drives: 2010 Camaro IBM 2SS\RS SC & Cammed
If you are on a hill you can hold in on the emergency button with it pulled up and when you take off just let the emergency brake go, hope this helps. The more you drive it the better you will get. At a light, depending on how long the light is, I usually just leave the clutch in till I am ready to go.
onechuck is offline   Reply With Quote
Old 07-01-2009, 09:31 PM   #5
Mark A Collier Sr
Retired Army, 101st ABN
Mark A Collier Sr's Avatar
Drives: 2 SS/RS w/sunroof
DO NOT drive with your left foot on the clutch petal! It will mess it up.
Learn the balance of gas and clutch... You do not have to over rev to make it go! If you let the clutch out slow enough, you can start off without touching the gas!!
PRACTICE!!!! Parking lot, driveway... YOU can do it! I have my 14 year old son driving a stick already! You can do it!
"BABY" is a Summit White, 2SS/RS, My Tribute to the 13 years I served in the 101st Airborne Division!!!
ORDERED: 18 JUL 09 #NMMS88,
BORN ON 4 NOV 09 at 12:26pm VIN:63460~ HOME on 18 NOV 09!
"101BABY"
Mark A Collier Sr is offline   Reply With Quote
Old 07-01-2009, 09:35 PM   #6
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Good advice while on a hill. When I am at a stop light I almost always put it in neutral and then just relax. Some of the lights can be rather long.
Old 07-01-2009, 09:39 PM   #7
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
At a red light, put it in nuetral with the clutch out and your foot off the clutch pedal. Take it easy on the throw out bearing.
Old 07-01-2009, 09:43 PM   #8
Rtoups
Rtoups's Avatar
Drives: RJT 2LT
I must say, this is helping me, and I don't even have a car yet! But I plan on getting my V6 Camaro with a manual transmission, and this is making me less nervous.
SoCal Camaro5 Family Member
Rtoups is offline   Reply With Quote
Old 07-01-2009, 09:43 PM   #9
Yellow2010
Yellow2010's Avatar
Drives: Rally Yellow 2SS 2010
Good advice. That is how I learned taking off from a hill.
Yellow2010 is offline   Reply With Quote
Old 07-01-2009, 09:54 PM   #10
tommygun6644
So, with your definition of riding the clutch, is it normal to ride it for split seconds at a time when your taking off (balancing it with the gas) or shifting? Maybe I just need to be quicker or more fluid.
Old 07-01-2009, 10:10 PM   #11
jdbaker82
Banned
Drives: None
From what my dad told me you should put it in neutral at a light its never good to keep the clutch depressed any longer then it needs to be.
jdbaker82 is offline   Reply With Quote
Old 07-01-2009, 10:10 PM   #12
jdanza
jdanza's Avatar
Drives: 2010 2SS/RS VR-BLACK
Put the car in neutral when your not moving, depress the clutch as few times as you can, try never to hold the pedal down too long. This will prevent wear on the clutch and the T.O. bearing , very costly to replace.
2010 2SS/RS VICTORY RED / BLACK LEATHER - 6 SPEED M TRANS
6000 = Delivered To Customer-8/22/2009
jdanza is offline   Reply With Quote
Old 07-01-2009, 10:39 PM   #13
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
Do all the above, just avoid using the clutch eased out to hold the car on a hill or any incline.Use the brake and the emergency brake if some one pulls in close behind you. You will get to where lightning fast your off the brake and out just right on the clutch and on the gas for a smooth start like a pro. It helps to not allow the guy behind you to get too close, on a hill you will usually roll a tad so just ease up a little if you see him come in too much.
tjbusa is offline   Reply With Quote
Old 07-01-2009, 10:41 PM   #14
jakemaxx
jakemaxx's Avatar
Drives: 1969 impala
if there is someone on my bumper i put it in reverse so they see the lights
ordering 1SS, IOM, White Stripes, Sunroof, BA Sound System, RS Package, LS3 6M
:5thgenvert:
jakemaxx is offline   Reply With Quote
Manual or Auto?--resale value question armando416 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 01-17-2012 09:06 PM
Tap Shift & Manual Stick bumblebee123 5th Gen Camaro SS LS LT General Discussions 41 11-14-2010 07:55 PM
Can't Decide - Auto or Manual attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 209 01-04-2010 11:14 PM
LS3 Transmission Question Seawolf 5th Gen Camaro SS LS LT General Discussions 13 06-12-2009 03:16 PM
a picture says a million words, not any more nimnels Camaro Photos | Spyshots | Video | Media Gallery 47 05-11-2009 05:49 AM
