BORLA
Old 06-26-2013, 01:16 PM   #1
Mutant Racer
Mutant Racer's Avatar
Drives: 2015 2LT Torch Red C7 Stingray
Would you retro package your 2SS to a 1LE?
Your friendly neighborhood Mutant Racer has some money coming my way and if you were me would you 1LE your 2SS for the track?
Yes?
No?
Hellafreakinyeah!
No way dummy the 1LE is a joke!
Your thoughts?
Mutant Racer is offline   Reply With Quote
Old 06-26-2013, 01:38 PM   #2
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
I'd get the 1LE gears and possibly rims and tires. The suspension parts would be better if you went aftermarket.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 06-26-2013, 01:40 PM   #3
SPCBA
Drives: pleather and Chiclets
the 1LE is hands down the best bang for your buck car out there.
there are improvements in the aftermarket. the rear end is nice but the rest can be beat quite easily in catalogs like pfadt or pedders.
SPCBA is offline   Reply With Quote
Old 06-26-2013, 01:42 PM   #4
Dynamite
Dynamite's Avatar
Drives: 2013 Camaro 2SS/RS XD
Yep. Just get the 3.91 gears and aftermarket everything else.
Dynamite is offline   Reply With Quote
Old 06-26-2013, 01:46 PM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Has GMPP released the 1LE track pack yet?
Old 06-26-2013, 02:09 PM   #6
Mutant Racer
Ok cool fellas, I will keep things simple and go mostly aftermarket.
I was thinking gears, ZL1 wheels, and do the truss rod for the shits and giggles.
Should I also go aftermarket for brake lines?
My Camaro will definitely be tracked for road courses.
That's what the guy from the dealership told me. Can't say for sure if that is 100% accurate though.
Old 06-26-2013, 02:18 PM   #7
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
I may be wrong, but I am pretty sure that the transmission in the 1LE has different ratios to counter that 3.91 gear that you would be so quick to put in..basically 1st gear would be useless with the current 2SS ratios and 6th would be like 5th.
Mikes SS is offline   Reply With Quote
Old 06-26-2013, 02:23 PM   #8
Mutant Racer
I know people that installed the Vette ZR1 clutch to go with the 3.91 gears. I saw one on the dyno that when it was punched in 4th the power was total shock and awe.
I have to do plenty of homework on this stuff but my guy also mentioned there is different short throw on the 1LE's from the people who have the Hurst factory short throw.
Old 06-26-2013, 02:26 PM   #9
mikeyg36
mikeyg36's Avatar
The ratios are different but it won't make 1st useless. On an auto it would, but not a manual.
Old 06-26-2013, 02:26 PM   #10
mikeyg36
mikeyg36's Avatar
Different name, same throw reduction.
Old 06-26-2013, 02:30 PM   #11
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
If I wanted a 1LE... I would get a 1LE.
If I wanted a ZL1... I would get a ZL1.
If I wanted a Vette... I would get a Vette.
Follow my thinking here?
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 06-26-2013, 02:34 PM   #12
Ivan @ Southwest Speed
Why would you retro it when you've already paid for the upgrades?
I mean, all it has that you would really want is the bang for the buck but you've already spent it so..lol Kinda moot at this point.
I'd say the Brakes, Wheels, and Gears would be about the most you'd want out of it.
Or just go trade "down" to one and make out better.
Good luck!
Old 06-26-2013, 02:34 PM   #13
caverman
caverman's Avatar
Drives: '69 SS Convertible
You can see most of my mods in my sig and have a lot of the what the 1LE has in aftermarket. I still have OEM wheels which is my biggest weak point now but I just think they are better looking over the 1LE or ZL1 wheels.
I've had 3.91 gears for a good year or so now. I can tell you by no means does it render a M6 useless. Quite the opposite. It runs WAY better from street light to street light. Does it take away some of your top end.....yes a little....but not like you would think. At 55mph I lost 200 RPM. Its still very drivable on the highway and actually around town I now use 6th gear a lot more than I used to. The 3.91 gears are awesome in an M6 and I would never go back to 3.45.
Build Journal
Old 06-26-2013, 02:36 PM   #14
caverman
caverman's Avatar
BTW: as for brakes, yes, change out to stainless lines and some good DOT 4 fluid and you'll be good to go.
Get a clutch fluid separator as well.
Build Journal
