Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 06-26-2013, 04:07 PM   #1
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
autocross with my vert
looking into doing an autocross event this weekend. will be my first racing event for my 13 ZL1 convertible. any tips of tricks I should do? what PSI should the tires be set to?
my only mod is BMR drop springs. not sure it they will make a difference. im thinking just put it in comp mode(push button 2 times) no ptm in the vert.
thanks guys, cant wait to see how she does.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Jer4251 is offline   Reply With Quote
Old 06-26-2013, 04:11 PM   #2
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Have fun, wish I was going out there too.
Life is too short to drive cars that suck.
My build Thread
In or around Savannah GA on the first Sunday of the month? Come meet with us here around 11 am!
mmarx82 is offline   Reply With Quote
Old 06-26-2013, 04:12 PM   #3
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
why aren't you going again?
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 06-26-2013, 04:53 PM   #4
mmarx82
mmarx82's Avatar
My brother's birthday, I was gonna pay for both of us to go but he's too afraid to go in his slow car lol. So we'll be doing something else. Sept is the next one and it's the weekend after my dad's birthday so I should be all good to go for that one.
My build Thread
Old 06-26-2013, 05:21 PM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Bring some painters tape with you to tape off the bumper and rear quarter panels. Come marks suck!
Good luck and have fun! Remember smooth is fast!
Best regards,
Tyler
888-308-6007
Old 06-26-2013, 07:09 PM   #6
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 17 A10 ZL1,14 2ssrs,96,85,79,69&67
Justin is right. Smooth is fast. I run about 30 pounds in my tires. I would leave all the traction nannies on until you learn the track. Then gradually turn them off. By the end of the day I am usually running with none. If its hot out those goodyears work great. if not they suck. Drive hard brake early and hard and accelerate thru the turn.
Old 06-26-2013, 07:21 PM   #7
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
great info. Its usually hot as hell down here this time of year. cant wait to see how the heavier convertible handles on a closed course. it will be my first autocross so im not real confident maneuvering the cones. but i'll give it a whirl for sure. hopefully whoever does with me from camaro5 will be able to get some video or pics at least.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 06-27-2013, 12:00 AM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
my ZL1 felt like I was driving on ice with the factory goodyears at the autocross. I am going to try my drag radials next time because they have to be better.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-27-2013, 03:40 AM   #9
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
What pressure were you running? Did you try reducing the tire pressure to compensate?
ZL1-V is offline   Reply With Quote
Old 06-27-2013, 06:24 AM   #10
Stephen12ZL1
Drives: '17 ZL1 A10
all of the autocross gurus there said to run slightly higher pressure to compensate for the low heat in the tires and to keep the tires from "rolling over" on the tight turns. They recommended 36psi to start and adjust from there.
Old 06-27-2013, 07:40 AM   #11
2010SSRSM6
2010SSRSM6's Avatar
Do you have a roll bar in your vert? Some places won't allow you to run without one.
Old 06-27-2013, 11:57 AM   #12
boltvette
boltvette's Avatar
Drives: 1963 Corvette, 2001 Corvette
Very few organizers require roll bars for autocrossing. But it's a valid point. Check with them first.
You're going to find that you expend a lot of energy holding yourself in your seat through the corners. Angelwings Tech has the solution - Angel Pads. They fill the spaces between you, the door and the console so you don't need to be using your knees to brace yourself.
2-seater "Camaro" w/JMS Racing LS3; C5 Z06 trans; C6 ZR1 exhaust; Dynatech catback; Ron Davis radiator; trans, diff & engine oil coolers; Pfadt JOC Stage 1 bars & shocks; C6 Z51 brakes; Angelwings C5 Track Day Bar; Angel Pads!
boltvette is offline   Reply With Quote
Old 06-27-2013, 01:01 PM   #13
ZL1-V
ZL1-V's Avatar
I am really confused so maybe one of the "guru's" can clear this up? If by decreasing the pressure won't you get "more heat" into the tire carcass? Increased pressure will induce more sliding won't it? I have never done autocross, just spectated at the events which looks like so much fun! I have participated in track days before. Not yet with my ZL1.
Old 06-27-2013, 02:22 PM   #14
JDP Sales
JDP Sales's Avatar
You are correct, however the incresed tire pressure is more for tire ware than grip. You can get away with lower tire pressure if you have the proper camber, but with street alignments it is best to air the tires up to prevent the tire from rolling over and murdering the outside edges of the tires. Especially on heavier cars, it is not uncommon to see guys running 40-45 psi in the front tires.
The proper tire pressure depends on camber settings, how stiff the sidewalls of that particular tire are, and the surface conditions of the pavement/asphalt you are racing on.
Best regards,
Tyler
888-308-6007
