JDP Motorsports
Old 06-26-2013, 07:27 PM   #1
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Odd-ball question regarding Stabilitrak
Was wondering if it is the case or not....If you run a road coarse with Stabilitrak "on", that is in "normal" or "stock" mode, and under certain conditions Stabilitrak will apply brakes without you using the brake pedal, or you being aware of it....
....my question is do the brake lights come on if Stabilitrak is applying the brakes and not the driver with the pedal? and when Stabilitrak does apply brakes, is there a dash light that comes on, or a message on the DIC that Stabilitrak is assisting/applying the brakes?
(Hopefully this is a legitimate question, Thanks!)...lol...
90503 is offline   Reply With Quote
Old 06-27-2013, 11:15 PM   #2
Synergy SATX
Mike and Debbie
Synergy SATX's Avatar
Drives: 2014 Corvette Stingray 3LT Z51
Should have a stabilitrack warning light on when being used if I recall. I know on ZL1 you get a HUD message.
Synergy SATX is offline   Reply With Quote
Old 07-06-2013, 07:12 AM   #3
RS117
RS117's Avatar
Drives: 2011 2LT/RS
I am not sure of the brake lights turn on. I doubt it.
I've had stability track turn on when I'm driving (happens when I go over a railroad track and get a little air). A message shows up on the DIC and HUD that reads "Stabilitrack Active"
RS117 is offline   Reply With Quote
Old 07-07-2013, 08:59 AM   #4
MikeOD
Drives: 2010 M6 2SS
Brake lights only come on when you use the brake pedal.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
