sjm autoprod
Old 06-26-2013, 08:18 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Exhaust brace??
What's the brace that the exhaust runs above? My exhaust is starting to rub against it @ a certain RPM. Can it be removed or maybe spaced down some? Thanks
Craig B is offline   Reply With Quote
Old 06-26-2013, 08:20 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Do you have an aftermarket exhaust? I would not remove the brace, its there for a reason. Some people add washers to drop it a bit or buy a new one (tunnel brace) that has more room.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 06-26-2013, 08:30 PM   #3
Craig B
Craig B's Avatar
Drives: 2013 1LE
I have LT headers and axle back exhaust. Washers it is, thanks.
Old 06-26-2013, 08:37 PM   #4
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Or this!
http://item.mobileweb.ebay.com/viewi...d=270941262316
csjcsj is offline   Reply With Quote
Old 06-26-2013, 08:45 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I got rid of mine in 2010 it's been in my garage ever since. After the Chokemaster 3" catback I bought though. It's really useless.
Old 06-26-2013, 08:59 PM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Tunnel braces aren't useless, they are there for a reason or else they wouldn't be required on any vehicles that have a specific channel for the exhaust. They are there specifically for side impact collisions as tunnel braces help distribute the forces and can be the difference between a minor collision and a major one. The bends for the channel inadvertently creates a crumple zone that in side impact collisions will give way.
As for the OP, a properly installed 3" exhaust will not contact the tunnel brace. If the exhaust is rubbing then there is a droop in the exhaust that should not be there. Loosen the connections and push up on the exhaust to straighten it out. If done correctly there will be plenty of room between the exhaust and the factory tunnel brace.
Mr_Draco is online now   Reply With Quote
Old 06-26-2013, 09:22 PM   #7
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Ain't gonna happen on my JBA system. Plenty of other people have properly installed exhausts that contact the tunnel brace. How hard would you have to squeeze that tunnel brace to get it to fold up? Not that hard. I'm thinking a little shop press would do the trick. Where is the proof that it does something in side-impact collisions? I have never seen it, but I don't dispute that it is out there. I'll be on your side as soon as I see the data.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-26-2013, 09:37 PM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
Don't have crash data to prove it does something, but I will argue that you keep it through another avenue. How much material do you think the tunnel brace is made out of? $10? $20? What about the four bolts that hold it in place? $5?
Why would Chevrolet spend the money to put one on every single Camaro if it didn't do anything? They are literally spending, what's probably, millions of dollars per model year to put them on our cars. There has to be a reason that the engineers needed to have when they pitched the idea of a "tunnel brace" to the finance guys.
See what I'm saying?
Click to view my build thread
Old 06-26-2013, 09:42 PM   #9
thahemp
Geek
thahemp's Avatar
Yep. That's a good point. I have known engineering departments to waste money before though. Whether it be carry-overs from copy/pasted engineering, or just oversights in general.
What if it was copied over from a previous body design and it actually inhibits a crumple zone in this particular cabin? I know that is probably just BS, but there is a good reason data should be provided for stuff like this.
x = ~x
Old 06-26-2013, 10:59 PM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
Originally Posted by csjcsj View Post
cool man, thanks for the link
62nalide is offline   Reply With Quote
Old 06-26-2013, 11:17 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Have you seen how flimsy these "braces" are? Do you really think they will absord or withstand an impact? Hell NO lol.
Old 06-26-2013, 11:27 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I'd have to disagree with ya deputy dog. It's for lateral stability across the tunnel. Those ridges pressed into the brace make it exponentially stronger for side to side strength. Once bolted in place, you can literally hang from it and it won't bend. I will say that once you put washers on it, you'll lose a lot of it's efficacy.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-27-2013, 01:30 AM   #13
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Elite Engineering makes a nice billet aluminum replacement for this brace. It also adds additional clearance for aftermarket exhaust.
LSX Camaro is offline   Reply With Quote
Old 06-27-2013, 09:08 AM   #14
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
The brace doesn't interfere with my kooks cats and Blowmasters
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
