SDTW Custom Wheels & Tires
Old 06-26-2013, 08:48 PM   #1
pdiddy
Drives: 2011 2SS
what hp do you think I will make
I just bought a maggie today going to run the stock pullie 3.8 I believe it is, I have long tube 1 7/8 headers high flow cats 3" exhaust bbk cai I am going to use 55lb injectors and either a bap or the zl1 pump, it will be custom tuned and probably run a little colder spark plug. what kind of rwhp and torque do you think I will make.
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 06-26-2013, 08:50 PM   #2
Supercharged SS
Drives: 2010 Camaro
530 rwhp. What do I win?
Old 06-26-2013, 09:00 PM   #3
pdiddy
Drives: 2011 2SS
I meant to type 52lb injectors its the ls9 ones that come with the kit I believe. Will these injectors be sufficent with that pullie and my other mods. I would be happy with 530 for awhile. Also with this set up is a bap and or a zl1 pump required
Old 06-26-2013, 10:00 PM   #4
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
You get the satisfaction of knowing you may have been right. lol
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 06-26-2013, 10:06 PM   #5
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
I'm all ears as I have basically the same set up
11syn3rgy is offline   Reply With Quote
Old 06-26-2013, 10:09 PM   #6
Supercharged SS
Drives: 2010 Camaro
I'd rather have a cash prize.
Old 06-26-2013, 10:10 PM   #7
Supercharged SS
Drives: 2010 Camaro
No bap or bigger injectors needed. You'll end up between 515-530.
Old 06-26-2013, 10:33 PM   #8
pdiddy
Drives: 2011 2SS
so u are saying I can safely run my stock fuel pump with this set up and not run into issues. I thought for sure I would need a pump or bap. hmmm and yes synergy we are in the same boat on the same day lol.. feels good though just alot to think about at once. I am using the ls9 injectors got some for 200
Old 06-26-2013, 10:38 PM   #9
Supercharged SS
Drives: 2010 Camaro
Stock pump is fine with that 3.8 pulleys. Most everyone in your range is doing this. A bap would be great but not needed.
Old 06-26-2013, 10:44 PM   #10
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
None of us have money all wasted on forced induction
1969to2010 is offline   Reply With Quote
Old 06-26-2013, 10:50 PM   #11
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Glad I'm not the only one....
Old 06-26-2013, 10:52 PM   #12
pdiddy
Drives: 2011 2SS
so if you where going to do the a fuel system upgrade would u do a bap or zl1 pump
Old 06-26-2013, 11:03 PM   #13
1969to2010
The Man in Black
1969to2010's Avatar
Zl1 fuel pump has worked for me
Old 06-26-2013, 11:11 PM   #14
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Like
lol
