Old 06-26-2013, 11:22 PM   #15
pdiddy
Drives: 2011 2SS
didd you do the adm deal on the zl1 pump of just the pump
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 06-27-2013, 05:59 AM   #16
Supercharged SS
Drives: 2010 Camaro
I've had the LPE duals for 3 years and its been flawless.
Zl1 pump over the bap if you were choosing one.
Old 06-27-2013, 07:53 AM   #17
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
not gonna see 530rwhp on stock maggie , if this is a l99...wishful thinking on jamie,s part
mikepage0007 is offline   Reply With Quote
Old 06-27-2013, 08:06 AM   #18
Supercharged SS
Drives: 2010 Camaro
Ls3 with headers and a cai. Easy 515. It'll make almost 500 with no headers or cai.
Old 06-27-2013, 08:28 AM   #19
mikepage0007
Drives: 2010 camaro
op needed to state whether he has the l99 or ls3...also loaded dyno can read 5% different then a unloaded dyno...lots of possibilities on rwhp
Old 06-27-2013, 08:46 AM   #20
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Just drive it and enjoy .. Yes dyno numbers can fluctuate, temps out side have a lot to do with it too ... Stock Maggie is strap on 100 plus. He was already over 400 so he will be over 500.
Mchlgrrsn is offline   Reply With Quote
Old 06-27-2013, 02:57 PM   #21
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2012 Silverado LTZ
With my E-Force S/C with 52# injectors, LT headers and axle back I was running out of fuel. I installed a ZL1 fuel pump and 72# injectors. It's running fine now with 546/rwhp. It's on an LS3.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 06-27-2013, 03:56 PM   #22
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
My L99 went from 350 HP to a tad under 500 HP on Livernois' dyno after the Maggie w/3.6 pulley. Since you have the LS3, I'd guess maybe 540-550 whp.
E.T. is offline   Reply With Quote
Old 06-27-2013, 03:57 PM   #23
Birm
Birm's Avatar
Drives: Florida Speed & Power
538whp
Birm is offline   Reply With Quote
Old 06-28-2013, 08:03 AM   #24
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
What ever the numbers are the car is going to be a lot of fun good luck
1969to2010 is offline   Reply With Quote
Old 06-28-2013, 09:03 AM   #25
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
I have basically the exact same set up as pdiddy but mine is a L99. With the stock 3.8 pulleys (for now), LS9 injectors, ZR1 plugs and the stock air box, where should I be for RWHP. Without the Maggie I had a dyno run of 375 to the rear wheels. It's sounding like the LS3 makes quite a bit more HP than the 26 additional that it starts with? Any thoughts.
11syn3rgy is offline   Reply With Quote
Old 06-28-2013, 10:18 AM   #26
E.T.
E.T.'s Avatar
You shouldn't have trouble breaking 500 rwhp. My L99 always seemed to dyno a little low. I was only in the 350 HP range with full bolt ons. The Maggie added almost 150 rwhp, but I went with the 3.6 pulley which is supposed to be 8 psi. Also, I have gears, which I've read will contribute to slightly lower numbers on the dyno. At any rate, don't get too caught up on the numbers. Adding a supercharger was one hell of an upgrade. The car is an absolute beast. At this point, the main thing holding it back is traction
Old 06-28-2013, 10:31 AM   #27
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Thanks man. If I go to 3.6 pulleys, will I need anything more than my LS9 injectors on the fuel side? I know a BAP is a good insurance policy, but at what level are these "necessary"?
Old 06-28-2013, 10:44 AM   #28
E.T.
E.T.'s Avatar
Here's what they put in mine:
SHOPSUP VARIOUS SHOP SUPPLIES, TOOLING,
LBRVEHICLE LABOR TO BASELINE DYNO, INSTALL
HAZARDOUS MATERIAL DISPOSAL
MAGNACHARGER SUPERCHARGER, CAI INC
TUBE FOR MAGGIE, 60# INJECTORS,
INJECTOR ADAPTERS, 3-BAR MAP, 160
THERMOSTAT, NGK PLUGS, MSD WIRES,
ZL1 PUMP, 3.6 PULLEY
I wasn't too familiar with all the requirements, so I just took their word for it. Best bet is to ask you shop/tuner, or maybe someone else on the forum will chime in.
