Old 07-01-2009, 10:55 PM   #1
Blueclyde
Blueclyde's Avatar
Drives: 2016 2SS
Clear Coat Issue - Rally Yellow 2SS/RS
I picked up my 2SS/RS almost a month ago. It is Rally Yellow with black stripes. A day after I got it home, I put the first coat of wax on it and found a run in the clear coat at the bottom of the driver's side door. I was VERY disappointed to see that. In looking at the passenger door I found a smaller but similar defect. These both fall into the category of "things only I will notice". An on-looker would likely never see them. It still drives me absolutely nuts to think that this would not have been caught at the plant or the dealer. The first time I hit it with a cloth I saw it. If I would have seen it at delivery I wouldn't have taken the car. I'm kind of picky. This car is my play car and may see 2000 miles per year.
I took it back to the dealer and the options are not good. It can be wet sanded with 2000 grit and rubbed, but cannot be fully removed without going through the clear coat. That would then require color and more clear coat. The painter at the dealer did not like the idea of repainting the door. I told him I didn't like it either. The painter said sanding and rubbing would make it better.
So, what to do? I'm thinking of leaving it alone and just stewing about it. Thoughts welcome from any of you paint shop guys out there.
Blueclyde is offline   Reply With Quote
Old 07-01-2009, 11:04 PM   #2
Vash
Drives: 00 Blazer
Leave it alone and don't worry about it.
Just add's flavor and it's minor.
Old 07-01-2009, 11:10 PM   #3
Thrillz
Thrillz's Avatar
Drives: 2012 Charger R/T / 2012 Dodge Ram
Ask Steve in the wash and wax section from tropic care. He's a pro detailer he can give u solid advice. U have options but for now i would leave it alone and chew on it for a while.
Thrillz is offline   Reply With Quote
Old 07-01-2009, 11:17 PM   #4
9c1ny
9c1ny's Avatar
Drives: C6 Zed-oh-six
mine has a run near the bottom of the passanger door
these are cars , nothing to get all OCD about, the quality control of the 1st gen camaro was alot worse I bet
9c1ny is offline   Reply With Quote
Old 07-01-2009, 11:18 PM   #5
FISHTAIL
FISHTAIL's Avatar
Drives: Sedan & 2SS / RS
Sometimes vehicles get minor damaged when they're transported and the dealer's body shop repairs it. I think that they can repaint up to 3 panels and still sell it as new. don't quote me on that though.
I'm not saying that’s what happened, just a possibility.
Drives: 2012 2SS/Black/RS/A6
FISHTAIL is offline   Reply With Quote
Old 07-01-2009, 11:23 PM   #6
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
wet sanding it shouldn't require more paint and clear to be put on. It should only even out the clear coat and then be buffed to factory shine.
BigMatt is offline   Reply With Quote
Custom Painted Stripes Underway for Bumleb's Rally Yellow 2SS RumbleBeeSS Cosmetics and Lighting Modification Discussions 140 06-20-2010 01:12 AM
Is it possible to add sort of a tinted clear coat to the factory exterior color? PatrickfromMD Cosmetics and Lighting Modification Discussions 3 08-27-2009 08:41 AM
Rally Yellow -> Bumblebee Sunrise for $10-$20? mcernik Cosmetics and Lighting Modification Discussions 20 08-04-2009 02:15 PM
Some Personal Modifications DIYs Forrest Camaro DIY & HOW-TO instructions & discussions 5 06-15-2009 06:17 PM
Zr1's clear coat. shank0668 General Automotive + Other Cars Discussion 21 09-28-2008 01:21 PM
