sjm autoprod
Old 06-26-2013, 11:52 PM   #1
Bigtime53
Bigtime53's Avatar
Drives: 2015 ZL1
LED tailights
I have seen a few cars on here that have the LED tailights. I would like to order some.Can someone tell me who the vendor is? I have not posted pics of my car yet because I have been hooked up at work and have not had the time to take pics. I have added some mods and when I get what I want done I will take the time to take some and post them.
Bigtime53 is offline   Reply With Quote
Old 06-27-2013, 08:04 AM   #2
Bigtime53
Bigtime53's Avatar
Drives: 2015 ZL1
I have LED tailights on my rock crawler jeep and they do not need to be turned off when parked and it sits for months at a time. If that is the case and they have to be turned off I do not need them on my car. Thanks for the heads up.
Old 06-27-2013, 08:43 AM   #3
Asanti
Asanti's Avatar
Drives: 2013 Camaro ZL1 Convertible
I got the same taillights but got them from these guys: http://www.apex-speed.com/index.php?dispatch=products.view&product_id=30268. They are really cool and they weren't directly hooked up to the battery so they don't drain it. I get lots of good comments about them.
2013 ZL1 Black Convertible
2002 Rally Red Camaro Z28 Convertible 35th Anniversary Edition
2008 Hummer H2 Ultra Marine Edition
Asanti is offline   Reply With Quote
Old 06-27-2013, 08:45 AM   #4
Sugar's ZL1
Ron and Sugar
Sugar's ZL1's Avatar
Drives: 2013 Black ZL1 Vert A6
As I have read, the culprit for draining the battery is the pink wire that goes directly to the Positive of the battery. That wire is for the "show mode" when at a gathering or showing your friens. Drop that wire and you will not have a battery drain as described.
Read this Camaro5 Thread http://www.camaro5.com/forums/showth...=Technostalgia
I Love My 08 Pek a Poo
Sugar's ZL1 is offline   Reply With Quote
Old 06-27-2013, 09:10 AM   #5
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
I had a Gen 1 set in my SS that were garbage....I have a Gen 2 set in my ZL1 now and they are great. I only had one issue with the driver outer having moisture in it, resealed and no more issue, the quaity is so much better the second time around. I forgot where I got mine MobFaab or something like that...I can't remember as I am overseas right now. Also the car sits any where from one to two weeks before starting, no issues so far with battery drain.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 06-27-2013, 05:23 PM   #6
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
The pink wire is to power the lights and needs to be connected to +12v in order for them to function. It can be hooked up to a wire that is has +12v only when the ignition is on. That will eliminate the battery drain. The purple wire is for show mode. Ground it to activate it.
Currently in the fleet... 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 06-27-2013, 06:12 PM   #7
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
If you don't hook up the pink wire, the lights will not work. The purple wire is optional.
Deke736 is offline   Reply With Quote
Old 07-01-2013, 12:44 AM   #8
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
aacstyle.com known as Advanced Automotive Concepts. I have the LEd Tailights, LED side markers, LED Headlight Halos, and LED Foglight Halos
69NMYSS is offline   Reply With Quote
Old 07-01-2013, 07:29 AM   #9
BAD ZL1
BAD ZL1
BAD ZL1's Avatar
Drives: 2013 VIN 48 Victory Red ZL1!
Man, those lights sound like a pain in the ass.
BAD ZL1 is offline   Reply With Quote
Old 07-01-2013, 07:56 AM   #10
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
Not at all
All you have to do is wire the pink wire slightly differently to how they tell you in the instructions and they are no problem whatsoever.
And even if you don't they only cause a problem to cars not started at all for a few weeks.
Modern07 is offline   Reply With Quote
Old 07-02-2013, 07:17 PM   #11
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
The video looks awesome!
ACTIVE INTERCHILLER.COM Fl INTERCHILLER
Original SUPER CHILLER Since 2009
Original XTREME CHILLER Since 2013
FACEBOOK 727 656 1422
Email Orders and Inquires
TrekGTO is online now   Reply With Quote
Old 07-04-2013, 01:30 PM   #12
zl1bro
Drives: 2013 ZL1 M6 SIM AGM mono stripe
I have a brand new in box set of AAC Oracle afterburner tail light halos. Decided at last minute to go in another direction. If anyone is interested PM me. Available at a good price.
zl1bro is offline   Reply With Quote
Old 07-04-2013, 04:44 PM   #13
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
The hardest part for me was getting my gorilla hands in that little tight space and undo the screws. If you have small hands its a piece of cake. I ended up with bloody knuckles but it was well worth the trouble. They look great!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
