Solo Performance
Old 06-27-2013, 04:38 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Vortech ysi ??
Anyone running one of these on the street with a cog drive? If so, how are the belts holding up? I may be looking to go this route before the summer is over. How much RWHP do they make on 93 octane with LT headers and a tune? Any info would be great. Thanks.
Craig B is offline   Reply With Quote
Old 06-27-2013, 04:43 PM   #2
Unreal
Drives: 2006 Z06
RWHP will depend on boost, motor, cam, etc. Anywhere from 500-1100 depending on the setup. For just LT and a tune it is way oversized. A Ysi is a 800-1100rwhp blower. If you aren't building the motor and drivetrain I would get something else.
Nick
Corvette Z06 -1200ish rwhp
Old 06-27-2013, 04:59 PM   #3
Craig B
Craig B's Avatar
Drives: 2013 1LE
I was looking to start out with say 600 RWHP and have some room to grow with the unit. I don't want to be maxed out and not be able to turn the wick up. Since the LS3 is new, I'm not looking to tear it down anytime soon. If I ever do, I will do a new rotating assembly with forged pistons.
Old 06-27-2013, 05:30 PM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
I'm running a ysi with a cog drive on a street car with an M6. No issues at all with the drive other than something got between the crank cog and the belt and caused the belt to come apart in the middle and gouged the cog. I dremeled down the sharp spots and luckily had an extra belt on hand. No problems since.
I made 825rwhp/639tq with it on 93 octane. Since that dyno run, I installed meth as just a safety feature, a cam speced for the engine, and pullied down the blower. I went from 15.xx lbs of boost to right at 20# of boost. I don't know what it makes now but it is noticably more powerful. I am guessing around 900rwhp but will dyno it soon.
I am running a procharger 77T crank cog with a 27T blower pulley. Before, I was running a 75T crank and 32T blower pulley. I also paired it with the BV57 blowoff valve too. There is nothing stealth about my setup.
If you have any other questions, PM me as I often forget to check threads I have posted in.
Oh, the cog setup sounds badass too...
Old 06-27-2013, 05:49 PM   #5
Craig B
Craig B's Avatar
Drives: 2013 1LE
Can you turn it down to make 7 or 8 psi.? Or will it not go that low?
Old 06-27-2013, 06:16 PM   #6
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
With a wastgate and boost controller yes but he doesn't have one so pulley swap will regulate boost.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 06-27-2013, 07:16 PM   #7
blake-b
blake-b's Avatar
Drives: Black 2010
This. I am not sure even by running the smallest crank pulley with the largest blower pulley you would make less than 10 psi. If you aren't planning on turning up the wick in the future, I'd go with a v3, an ecs kit with novi 1500, or a procharger d1sc if your heart is set on a centri.
If you are wanting to turn it up in the future, you will need a wastegate and boost controller to keep it down in the meantime.
Old 06-27-2013, 07:41 PM   #8
Craig B
Craig B's Avatar
Drives: 2013 1LE
Ok thanks. Back in the late 90's I ran a D1 on a SBC and was maxed out @ 16 psi. I was looking to make more power and that was all she had. Just don't want the same thing to happen.
Old 06-27-2013, 08:03 PM   #9
Unreal
Drives: 2006 Z06
T-trim, Ti-trim, D1SC, Paxton 1500, or just do turbos would all be a better choice.
Nick
Old 06-27-2013, 08:18 PM   #10
Camper
Banned
Drives: 10' 2SS LS3 M6
stay away from the ysi with your setup
sup Nick!
Camper is offline   Reply With Quote
Old 06-28-2013, 12:05 AM   #11
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
I have the Ysi on right now with a lack of supporting mods. I WILL build the motor this winter though. My boost and dyno numbers are still unknown. Just been DDing it with an occasional pull for now. Not allowed to finish my build til I have enough money to buy my wife a bike.. lol.
K32 Camaro is offline   Reply With Quote
Old 06-28-2013, 03:40 AM   #12
Slickcas
Drives: 12' 2SS/RS LS3 IBM
The Vortech V3 is a killer little blower it can put out more then a stock LS3 can handle. Headers and a 3.33 pulley will put you at 600rwhp. The brackets will let you swap in a V7(YSi) if you decide to forge the motor later.
BUT ECS has a very nice set up with the NOVI 1500 that will also take the V7(YSi). ECS uses a Restricter plate on the base setup that lets it build a lot of boost in the lower RPMs to give a more HP/Torque down low but keeps it from over boosting the stock motor at high RPMs.
Slickcas is offline   Reply With Quote
