Old 06-27-2013, 05:29 PM   #1
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
Seafoam induction?
Decided to seafoam the motor. It only has 5k on the clock w/o a catch can. My catch can finally arrived today and i want to make sure the motor is clean and ready prior to installing. Any recommend vacuum lines. I was going to induce it through the vacuum line via the back of the throttle body. Suggestions?
Sent from my hip pocket.. While slapping 5th.. As you're reading my plate
1Slow6.2 is offline   Reply With Quote
Old 06-27-2013, 05:41 PM   #2
turboguy327
Banned
Drives: 2011 Chevy Camaro
Get the aerosol can of seafoam. It comes with a straw you put inside the throttle body then reinstall the air ducting, run the engine and spray. It's much easier and I think does a better job.
turboguy327 is offline   Reply With Quote
Old 06-27-2013, 05:52 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I have always done the brake line vacuum way. But try it and get back to us.
Old 06-27-2013, 05:56 PM   #4
1Slow6.2
1Slow6.2's Avatar
I already bought 2 cans of seafoam and doing the 2 part cleaning of the engine/fuel system. Already filled up the tank and dumped a can of it in the gas tank.
Old 06-27-2013, 05:57 PM   #5
1Slow6.2
1Slow6.2's Avatar
Alright will do. I'll prob attempt it today. Which line on the back of the throttle body do I try it?
Old 06-27-2013, 06:01 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^are Vin Diesel^^ lol
Old 06-27-2013, 06:03 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
The one that connects to the brake booster, I disconnect it but I use my thumb to close it so it won't shut off. So don't let it and let it suck it up slowly in increments.
Old 06-27-2013, 06:30 PM   #8
1Slow6.2
1Slow6.2's Avatar
Not vin diesel more like Roman Pearce bruh! Lol thanks
Old 06-27-2013, 09:35 PM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The line right off the intake tube has to be the easiest. Cleans everything from the TB back.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-27-2013, 11:22 PM   #10
tanur420
Drives: 2011 Camaro SS
can you crank the car upand run the motor without air intake attached d spray through the tb opening with the aerosal? or will car not run without maf reading?
tanur420 is offline   Reply With Quote
Old 06-28-2013, 02:36 AM   #11
1Slow6.2
1Slow6.2's Avatar
Actually I decided to use the brake booster line. Did the induction portion and let it sit for about 20mins and I minimum to moderate smoke for about 3 hard pulls and the smoke was gone. Guess I didn't have to much carbon build-up! 👍Guess I broke that joint in right 🍺
Old 06-28-2013, 03:01 AM   #12
tanur420
have a pic of the brake booster line? only line I can think of would be either one going into air line or one on tb
Old 06-28-2013, 03:21 AM   #13
turboguy327
Banned
The straw goes between the TB and the ducting. The car runs without any MAF leaks.
Old 06-28-2013, 11:28 AM   #14
tanur420
how do you feather the throttle from the tb?
