BeckyD @ James Martin Chevy
Old 06-28-2013, 12:53 PM   #15
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
These headers not only have great ground clearance...they were also designed around the new electronic steering system which has a different knuckle....this means zero clearance issues across the board for everyone! The HP numbers have been great too
Old 06-28-2013, 12:57 PM   #16
Goo
Goo's Avatar
Drives: Cayman S
Seeing stock next to these are like
Goo is offline   Reply With Quote
Old 06-28-2013, 01:10 PM   #17
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
I want and need a set...thanks
Current: PFADT Drop Springs/ZL1 Rock Guards/SLP Skip Shift Elim./DRAKE Bowtie Delete/ELITE Catch Can/XPEL Clear Film/CORSA ZL1 Cat Back/Z28 CAI
SWAG1LE is offline   Reply With Quote
Old 06-28-2013, 03:55 PM   #18
Lycanine
Lycanine's Avatar
I have Doug Thorley tri-ys 1 7/8" and they rub the steering shaft on hard turns. I love their sound too much to go with another set...but if your headers have a similar sound and great numbers for the L99, I might switch them out!
Lycanine is offline   Reply With Quote
Old 06-28-2013, 06:16 PM   #19
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
No kidding. You think they might flow a little better?
Old 06-28-2013, 06:23 PM   #20
Juice2SS
Drives: 2011 2SS
Then where are the graphs???
Juice2SS is offline   Reply With Quote
Old 06-28-2013, 06:56 PM   #21
MattSS
Drives: 2010 2SS/RS A6 CGM
So will these bolt up to the stock cats?... I'm getting close to pulling the trigger on a set of SOLO hi-flow cats (which fit the stock manifold) + full catback with j-pipes and plan on doing headers next. I'd hate to spend the money and find out I'm gonna have to turn around and replace the cats again in a year.
MattSS is offline   Reply With Quote
Old 06-28-2013, 07:03 PM   #22
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
No, these come with HF cats. So forget the solos.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 06-28-2013, 08:55 PM   #23
Apex Motorsports
You can not use stock cats with long tube headers. You will also not be able to turn around and use the Solos with long tubes later. It is a totally different set up. Hold out on the cats and get them with your headers.
Old 06-28-2013, 09:16 PM   #24
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
Exactly! I had Solos with my shorties and had to sell them when I went LT's. I just bought the cats that go with the LT's and it bolted right up to my catback!
Old 08-12-2013, 07:44 PM   #25
SSeniorMoment
Drives: 2010 2SS RS L99 IOM
Another view of the Tri-Ys;
SSeniorMoment is offline   Reply With Quote
Old 08-13-2013, 06:25 AM   #26
Apex Motorsports
Great photo. People don't usually think to get one from the backside.
Old 08-13-2013, 02:53 PM   #27
bdrobLS3
bdrobLS3's Avatar
Drives: 2012 Camaro 2SSRS Manual Coupe
Send a message via AIM to bdrobLS3
the exhaust on my car has a 2 1/2 inch connection to a 3 inch x pipe do i need a new x pipe with these as well I bought the Flow Master AMT CAT back system
bdrobLS3 is offline   Reply With Quote
Old 08-13-2013, 06:23 PM   #28
Apex Motorsports
No, it will bolt up to your cat back.
apex motorsports, headers, long tube headers, pfadt, tri-y
