Solo Performance
Old 06-28-2013, 10:12 AM   #1
krusher
krusher's Avatar
Drives: 2010 Camaro SS/RS CGM
Power steering reservoir relocation
Any one do a mod moving the steering fluid reservoir off a 2010 or 2011 camaro? I have searched and saw some stuff where they dressed it up, but what about moving it to right next to the radiator or off to the side. What is required of this reservoir is it just a box with 2 ports and a vented cap? Would it be easy to just make my own?
krusher is offline   Reply With Quote
Old 07-01-2013, 02:37 PM   #2
krusher
krusher's Avatar
Anyone?
Old 07-01-2013, 03:35 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Why?
Old 07-01-2013, 03:40 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
I don't think it has a vented cap - but yes, it's basically a box with an inlet and an outlet.
Click to view my build thread
Old 07-01-2013, 03:46 PM   #5
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
I am moving my tank remotely and using a Lee's Power Steering tank with fins that helps cool the fluid. I am also using a Turn One Type two high performance PS pump. It's 6 ounces lighter than our stock pump. It has the AN fitting to connect your lines too. Before I went with the Turn One pump, I had the stock pump dissemble in order to mount machine the threading for the AN fittings. It's sitting on my shelf. I probably put it up for sale.
Moreno Motorsports is offline   Reply With Quote
Old 07-01-2013, 08:56 PM   #6
krusher
krusher's Avatar
Why? Because I can! Just cleaning up the engine bay
Old 07-01-2013, 11:34 PM   #7
tys2010camaro
tys2010camaro's Avatar
Drives: 2010 camaro ss
I asked this same question a while back. I realy didn't even request to relocate. I just wanted to find a nice looking billett reservior. I had zero luck. I am with you, the plastic has got to go!
tys2010camaro is offline   Reply With Quote
Old 07-02-2013, 03:13 AM   #8
The Stig
The Stig's Avatar
Question, did you connect the dirty side of your PCV system so it feeds directly into your intake?
Old 07-02-2013, 07:50 AM   #9
krusher
krusher's Avatar
In this pic I did not have the hose installed yet from the passenger side valve cover! I have one installed in the intake right now. For the automatic it kinda sucks to have to run a hose from the driver side rear valve cover to right behind the throttle body.
Old 07-02-2013, 10:50 AM   #10
The Stig
The Stig's Avatar
You're not putting a catch can in though?
Old 07-02-2013, 11:27 AM   #11
krusher
krusher's Avatar
I have one, but have not decided where to put it. I think its dumb to "clean" the engine bay and then start putting things on! I kinda want to hide it to be honest.
What would it matter this is the normal piping for a L99 correct or am I mistaken? The whole PCV system and vacuum hoses kinda get me flustered so if I have something not right please tell me.
Old 07-02-2013, 12:01 PM   #12
The Stig
The Stig's Avatar
What you have is not the OEM PCV piping set up. In OEM, the driver's side valley cover is capped and the driver's side valley cover part is connected to the intake (it's the male end that's right below where you have the line going into the intake).
Old 07-02-2013, 03:00 PM   #13
krusher
krusher's Avatar
http://www.camaro5.com/forums/wiki.p...specifications
If you read this at the very bottom the L99 automatic does not have this port in the valey plate. I went rounders in my head like did I miss something??? I have it piped the way a normal L99 would be, but yes an LS3 would not be piped in this way. By the way send me an answer to my message!!!
