Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 06-28-2013, 06:04 PM   #1
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
'69 Camaro
Anyone know how much a restored '69 Camaro w/15,000 mi/396 cu in/350 hp would sell for. A friend of my wife's is looking to buy one. Not sure if the 15K is original, or since the restoration. My guess would be since the restoration. Why would it need restoring w/only 15K original mi, unless it sat still since then. Thanks in advance for any feedback.
MYDLIFECRISIS is offline   Reply With Quote
Old 06-28-2013, 06:07 PM   #2
6camaro
Drives: 2010 SS
Anywhere from 13,500 - 25,000 depending on a host of variables.
6camaro is offline   Reply With Quote
Old 06-28-2013, 06:08 PM   #3
kmthor00
Drives: 2013 ZL1 Black
Is it a true SS? Makes a huge difference.
kmthor00 is offline   Reply With Quote
Old 06-28-2013, 06:17 PM   #4
arod55
AROD55
arod55's Avatar
Drives: 2010 Camaro 2SSRS/55 Chevy Bel Aire
As was posted if its a true SS and in above average condition it's worth quite a bit check NADA for values. They give you a range as to how much there worth. What makes them more valuable is if its a matching numbers car. I found one here in San Diego and the guys wants $28,000.
arod55 is offline   Reply With Quote
Old 06-28-2013, 06:18 PM   #5
gmen09
gmen09's Avatar
Drives: 2010 Camaro SS ls3
Is this a numbers matching big block camaro? If so its going to be a whole lot more than 13000-25000
gmen09 is offline   Reply With Quote
Old 06-28-2013, 06:22 PM   #6
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Look on the Mecum Auction website to see what they have been getting for them at auction. Depending its condition and if numbers matching I would say $30k is not unreasonable, maybe more
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 06-28-2013, 06:31 PM   #7
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
I would ask on a gen 1 forum, way too many variables to list to determine value.
This list is pretty thorough.
http://classiccars.about.com/od/sell.../a/Selling.htm
upflying is offline   Reply With Quote
Old 06-28-2013, 06:36 PM   #8
MYDLIFECRISIS
Thanks guys, real helpful. I'll get more info from my wife's friend, and post the variables. Thanks again!
Old 06-28-2013, 06:49 PM   #9
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Ask around on Camaros.net they can guide you for what to look for.
Beware of rusted trunks, lower rear quarter panels and around the window channels.
BigBlock69RS is offline   Reply With Quote
