Old 06-29-2013, 04:38 PM   #29
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
http://youtu.be/gve4jBFIkbM
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 06-29-2013, 05:28 PM   #30
killmode_on
Drives: 2011 2SS/RS
Originally Posted by partymn View Post
Kind of. Its not really as tough of a spot as it could be, I just want to minimize the backpressure and take that strain off my system. I am not changing the whole system and the turbo whine is too addicting to get rid of either.
Go back to stock, why would anyone do that. Its still sitting at 546 HP and 599 Tq, going back to stock would be like driving a Prius.
If the answer is as simple as being out of turbo, then so be it. I will live with what I got until I can financial justify doing further changes. However, there is always something that you can do that will not break the bank and still improve the situation. Throwing money at it is not the answer to every question on C5. I am just trying to figure out what is the correct route to take.
I think I see now how you got into this current mess. Enjoy.
Be vewy vewy quiet, I'm hunting GT500's.
killmode_on is offline   Reply With Quote
Old 06-29-2013, 05:54 PM   #31
partymn
partymn's Avatar
How is that, please enlighten me. If the answer is that I am cheap, you are correct.
Old 06-29-2013, 06:12 PM   #32
Unreal
Drives: 2006 Z06
Sell it and buy something properly setup. There will be no cheap way to fix it, and throwing more money at it won't ever get it to where you want it. Put it on ebay, sell it to someone who will be happy with 500rwhp, and then buy a nice turbo kit.
Nick
Corvette Z06 -1200ish rwhp
Old 06-29-2013, 06:17 PM   #33
partymn
partymn's Avatar
That may be an option in the future, if I find no other options. I just hate to break the budget and go backwards. Unless PCM can find a cheap option I guess I will have to live with what I got for now.
Old 06-29-2013, 07:27 PM   #34
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
There is not a cheap option.
JLE58 is offline   Reply With Quote
Old 06-29-2013, 07:41 PM   #35
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
You were already told. The only way to get the BP down without spending the money for another turbo and additional work is to turn down the boost. Drop it to 5psi and live with it for now and at that level the turbo should last and you shouldn't damage anything. Save money and either modify what you have or scrap it and go another route....lesson learned although it was the hard way sometimes ....well a lot of the times that is what happens.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 06-30-2013, 07:29 AM   #36
grocerygetter
instigator
grocerygetter's Avatar
Yup. U hit it. To give you an idea, my GN at 30psi had almost the exact same pressure in the exhaust mani. 6176 turbonetics turbo...76mm hot side with a .63 AR for spooling. That was a 3" single shot down pipe and exhaust on 3.8 with stock heads.
The .82 AR isn't going to help much. A single turbo is still a good choice. But IMO, 76mm. And with a turbo that big you want the exhaust wheel that size minimum and never neck down. So 3" to a dual 3" catback would be fine. Even 3" to a dual 2.5" catback would be ok. You have to use some type of straight through no back pressure muffler.
It would be worth your time calling precision turbo and seeing by chance if Patrick still works there. If not get one of the other techs and tell them what your are turbocharging and what your goals are. They don't have a kit, but they will tell you proper snail size.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 06-30-2013, 10:27 AM   #37
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
if its got that much back pressure then there should be room to grow. back pressure is just a measurement of restiction.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 06-30-2013, 11:27 AM   #38
partymn
partymn's Avatar
Thanks guys. My build budget will not hold up with the extra expense of changing the turbo. Looks like I will live with what I got until after Camarofest, then I will change to the biggest turbo that I can fit in that space safely.
Old 06-30-2013, 12:19 PM   #39
ayousef
ayousef's Avatar
Drives: 2013 ZL1
you can probably spec a custom cam for a backpressured system, not sure HOW much this could help but I know it does.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 06-30-2013, 12:20 PM   #40
Unreal
Drives: 2006 Z06
How much do you have to spend then? You can get the correct turbo for $1300 or so. You can sell yours for $600-700. So you need to invest $600-700 to get it fixed. That isn't bad at all.
Nick
Old 06-30-2013, 01:10 PM   #41
JLE58
I can get you a comp pretty cheap party when you get ready. A ct43 76/79 would be great and would be very similar in size about an inch bigger. I thought these kits came with a ct43 but when I look back at the hps sale thread they are ct4's which is even smaller than I thought.
Old 06-30-2013, 01:45 PM   #42
partymn
partymn's Avatar
Yea its a CT4 67/67 with a .96 AR. JLE58, how cheap are we talking?
