JUICEDMOTORSPORTS
Old 06-28-2013, 11:51 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2010 Camaro 2ss M6
cam first start up question?
When you do your cam install do you have to get the RPMs at a certain speed or you would be fine just letting it idle for a little?
TheBandit18 is offline   Reply With Quote
Old 06-29-2013, 12:18 AM   #2
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
You need to break in the springs with the proper heat cycles, or whatever they're called, assuming you replaced the springs as well. Ask litle88 about it.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 06-29-2013, 12:20 AM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You rang? Lol
Old 06-29-2013, 12:23 AM   #4
TheBandit18
I'm doing the install tomorrow. And I will be replacing the springs. I know about the spring cycles. So is there any specific technique after the first start like revving to a certain RPM
Old 06-29-2013, 12:24 AM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yea but it will attempt to hunt for its idle and it might die the first couple of times but don't get on it please. Just let it idle for a while then shut it down and jet it completely cool then start the process a few times I've done it 3-5 hear cycles til it's ready to get on the dyno. So DO NOT get on it til then.
From now on remember that your springs NEED HEAT to function properly and NEVER get on it with cold springs because they might break!
Hope this helps bud.
Old 06-29-2013, 12:26 AM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Also please make sure your spring installed height is correct.
Old 06-29-2013, 12:29 AM   #7
TheBandit18
Thanks!! Helps a lot! I have been training myself every morning to let it sit after starting to let it idle down and warm up.
And another question how are the spring going to cool down if where I'm at has be in the 100 degrees the last few days
Old 06-29-2013, 12:31 AM   #8
TheBandit18
How will you be able to check? I'm doing the night fury cam package I talked to Shawn about what to get so.... Yea
Old 06-29-2013, 12:36 AM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Good cam!!
I know it's hot but a complete cool down would be just to ambient temps for a lack of better words a good 1hr / 1.5 hrs cooling off would be good.
Old 06-29-2013, 12:42 AM   #10
TheBandit18
Ok. So what is the height they have to be and how to check?
Old 06-29-2013, 01:26 AM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Here you go
http://www.cpgnation.com/forum/comp-...tech-2047.html
Old 06-29-2013, 01:28 AM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
The installed height will be on the box with open and closed pressures.
Old 06-29-2013, 08:20 AM   #13
TheBandit18
Ok I appreciate it!
Old 06-29-2013, 10:51 AM   #14
Kelly@PCMofNC
Drives: 2010 RS/SS
Change the oil after your install also, good practice for any time you open up a motor.
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
