Cold Air Inductions
Old 06-29-2013, 01:18 AM   #1
phatbastard
Drives: 2013 Camaro 2ss 1LE
Stock 1LE shifter rattle driving me nuts, Help!
Have had the car since February, lots of fun. The rattle from the stock shifter is rather bad at low to mid rpms under any load. Installed the Dynapad kit from MGW on the stock shifter (inside the car). This reduced the other noises but just made the shifter rattle more noticeable.
I can reduce the rattle by holding slight pressure on the shifter, but each gear requires a different direction and pressure to reduce it.
Is it the shifter pin slop or the rod that is part of the transmission that tends to make the rattle noise? Can I shim the shifter pin and clips to reduce this? Do not want to use the sticky Dynamat in the AZ heat and gum up the link rod and shifter.
Any way to reduce the noise / rattle?
phatbastard is offline   Reply With Quote
Old 06-29-2013, 06:32 AM   #2
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
No rattles here. Run it by your dealer service dept for warranty repair.
Southern Comfort is offline   Reply With Quote
Old 06-29-2013, 06:59 AM   #3
fgg60
Sweet Annie!! BRM
fgg60's Avatar
Drives: '13 2SS/RS 1LE BRM NPP CF5
+1
FGG60 - (BRM 2SS 1LE) 1 of 70!!
fgg60 is offline   Reply With Quote
Old 06-29-2013, 08:51 AM   #4
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
+2
BigBlock69RS is offline   Reply With Quote
Old 06-29-2013, 09:17 AM   #5
NinoSS
Drives: 2SS/RS CGM LS3
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 06-29-2013, 09:54 AM   #6
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
Yeah that's not normal use your warranty.
CamaroTom is offline   Reply With Quote
Old 07-05-2013, 10:25 AM   #7
phatbastard
Had the car up on ramps to look for a fix for this. The only good news is that the stock shifter is a solid unit, no slops in the shifter, link rod or pins.
The bad news is the slop is in the transmission. The hole on the transmission shift shaft is larger than the pin on the shifter link rod.
No, easy fix for this and replacing the shifter assembly will not help. This is a hard area to get to and the only fix would be to remove the entire shifter, machine an oversize pin and enlarge the link rod holes to accept the larger pin. Have to live with it for now.
I'm not one of the people that like dealers and will take my car in ONLY as a last resort.
Old 07-05-2013, 08:02 PM   #8
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
It can sometimes be hard to find a good dealership. And there are many people that feel like you do. The only downside is when you work on things yourself, and then can't fix it and decide to take it in, the warranty claim can be denied because you were working on it.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 07-05-2013, 09:33 PM   #9
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Do you have rattling mechanical clunking? Mine clanks and clunks like mad at low speed (in and out of the driveway), but if I shift "right" it doesn't happen.
I used to gripe about this when I first got my 1LE but have no learnt to drive it a bit differently. Not that this should be the fix but it has worked for me.
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 07-06-2013, 06:39 PM   #10
phatbastard
Have the clutch chatter noise when I pull in the sloped drive also, that is normal. The shifter rattle is not as bad as some of the people with after market shifters have sometimes. I went back under today and used some 1/2" ID heater hose split down the length to cover the shifter link rod. This helped take the edge off the rattle noise, not that bad now. Everything looks solid and functions well so, just have to go with it.
Old 05-29-2014, 11:00 AM   #11
blapp
Drives: 2016 Camaro 2SS Conv
I had a 2013 2ss convertible about 3 months ago with the same symptoms. The rattle/noise would occur when under load and was much worse at higher rpm's. I took it to the dealership to have it diagnosed and resolved. There were actually a handful of camaro's (4 out of 12) at the dealership with the same symptoms - a mix of v8 and v6's. The dealership worked with GM engineers to try and figure out the cause. They said the issue was caused by "stacked tolerances" in the shifter linkage. They attempted mutlple fixes but could not resolve it. In the end I had to get rid of the car becuase I just couldn't deal with it anymore. I believe they are still working on a fix. Although they were not able to resolve it for me, I have to say GM and the dealership really stepped up on this one...unfortunately I just couldn't wait any longer.
blapp is offline   Reply With Quote
