B&M Racing
Old 06-29-2013, 12:37 PM   #1
Chapa3
Chapa3's Avatar
Drives: '10 2SS/RS
Slight problem when PlastiDiping Rims.
I recently put new tires on my camaro. I opted for 275s all around instead of the staggered 245-275 OEM tires. When I previously PD'd my rims, I put flash cards in between the gap of the rim and tire(to eliminate overspray), and it worked out great.
But now I have less of a gap between the front rims and the tires. I guess since the front rims are half an inch smaller? (Not sure). Anyway.. I could never get the plastidip to go behind the lip of the rim. It just kind of stopped at the edges, and it peeled off pretty easily.
Any suggestions?
Chapa3 is offline   Reply With Quote
Old 06-30-2013, 02:07 AM   #2
Dexter9522
Drives: SS
I managed to get the blue painters tape to stick to the tire once and was able to get back behind it. It's a PITA to get it to stick and be able to manipulate the wheel while painting without the tape wanting to peel off. Other than that it may be easier/ better to powdercoat them. Way more expensive but more of a long term solution.
Dexter9522 is offline   Reply With Quote
Old 06-30-2013, 10:56 AM   #3
IamBATMAN
Drives: 2011 Camaro 2SS/RS
I layed down double stick tape on the edge of the tire and laid down some painters plastic over the entire wheel. Once I got a good seal on the double stick tape I took a razor and cut out the plastic to expose only the rims. It took a little while to prep but was definitely worth the results and not having to touch up the rims once they were done.
IamBATMAN is offline   Reply With Quote
