Old 06-29-2013, 03:36 PM   #1
ColoradoSS
Drives: 2010 camaro SS/RS
2010 camaro protection with uprgrades
I already have a full exhaust, intake and a dyno tune, im wanting to install some 3.73 and a stall too, my question is what stall to go with, and what do I need to do to ensure my tranny is going to hold up to these mods. also since I've gotten my long tubes my cooler fan runs all the damn time, is this normal with the amount of heat the long tubes produce?
ColoradoSS is offline   Reply With Quote
Old 06-29-2013, 03:51 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Did you retune after installing the lower thermostat?
Click to view my build thread
Old 06-29-2013, 03:58 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
In the tune the fans must be set accordingly.
Old 06-29-2013, 04:06 PM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
Look into getting a bigger transmission cooler. But these A6 hold a lot of power.
62nalide is offline   Reply With Quote
Old 06-29-2013, 04:15 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
A stall does generate lots of heat and especially with gears too. A nice B&M and I believe phastek or TORQ have a nice tranny cooler. Iirc.
Old 06-29-2013, 04:30 PM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
I usually use the tru cool 40k cooler on my builds its big but drops 20 to 30*
Old 06-29-2013, 05:32 PM   #7
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
http://www.camaro5.com/forums/member.php?u=18009 You might want to talk to these guys, in your neck of the woods.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 06-29-2013, 06:38 PM   #8
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Look into the ADM Trans cooler. It is one of the best ways to keep heat down in a tranny! Mine doesn't get above 180 in the 100 degree heat under normal driving!
Camarojt is offline   Reply With Quote
converter, gear swap, heat, stall, transmission
