JUICEDMOTORSPORTS
Old 06-29-2013, 03:42 PM   #1
pdiddy
Drives: 2011 2SS
2 bar map sensor
So I am ordered a Maggie this week and got ahold of my tunner this week and asked him about using a 2 bar map sensor he said I didnt need to get one. I have read its more for tunning I am only going to be maybe low 500 hp but can anyone explain why I wouldnt need the two bar. Is this really just a tuner preference I know that my tunner is VERY experenced with tunning ls motors. He said they are really only a must at big hp like 1000+. Please school me on this and explain what this is really all about.
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 06-30-2013, 05:07 PM   #2
BLACK10
BLACK10's Avatar
its a 3bar map you need. we install on on every boosted build we do
Old 06-30-2013, 08:14 PM   #3
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
Jannetty says its a must as well. I believe it's to help the "remote" tuners really see what's going on, but I could be wrong? The part was only $40 anyways. It's a ZR1 3 bar map sensor btw. Good luck man
11syn3rgy is offline   Reply With Quote
Old 06-30-2013, 08:57 PM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
With the zr1 map sensor and your tune adjusted for it, you can also read boost through the obd2 port.
Old 07-01-2013, 09:27 AM   #5
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
It hay be a tuner preference. He is probably doing a MAF only tune. With a Maggie you will not max out the MAF. With that being said, the proper way to maintain control over your tune is to have the 3 bar MAP sensor on the car. GM does this for a reason on the ZL1. It is a good idea to have it to tune the car correctly.
Shawn
Lethal Racing is offline   Reply With Quote
Old 07-01-2013, 09:49 AM   #6
bikerdan
BLOWNSS
bikerdan's Avatar
Drives: 2011 SUPERCHARGED Camero SS
My experienced tuner doesn't use the 3bar either
2011 LS3 SS/RS, M6, Maggie TVS2300 - cog drive, CAI, ZL1 fuel pump, Autometer gages, BEHE Performance tune , boost and AFR gages, MGW shifter, SLP long tube headers with high flow cats, Flowmaster Pro ex., Pfadt trailing arms, toe rods & bushings, G-Force axles, American Racing wheels, 305 mm P zero on rear, Elite catch can, SLP hood, amp & sub.
bikerdan is offline   Reply With Quote
