06-30-2013, 12:51 AM | #1 |
I run 2 catch cans...
Deep purple footwell & inside door pull lighting
Here are some pictures of my install today. I used 4.8mm wide angle straw hat LEDs with resistors "IL319 Violet" from Microtivity Electronics on amazon.com (about $7 for 30).
I wired the footwell lighting into 4 clusters of 4 LEDs each, 2 clusters per side, all parallel wired. I also soldered a resistor to each LED. They are on a 3-way switch for dome-off-on. The door pull is a single LED+resistor, wired into the window switch. It has enough spill over to light up the sill when the door is opened. The purple is too dim to see in the daytime, but it really glows at night. I can't believe how awesome this looks with my gray interior.
Overkill tuned Air Scoop CAI VMAX PTB JacFab Laminator FX + Extendolator SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
06-30-2013, 01:10 AM | #2 |
HT5 COTW 1/21/13
Drives: 2010 Camaro Inferno 2SS RS 6M Join Date: Apr 2011
That is cool. I have my footwell LEDs still seating in the box lol
06-30-2013, 01:36 AM | #3 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
^ Installation isn't that hard. Get it done buddy.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
06-30-2013, 01:39 AM | #4 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
Now I want to get rid of my green lights and put purples that look awesome ! Where did you get em ?
06-30-2013, 12:48 PM | #5 |
Here's a 25 pack for $3.77: http://www.amazon.com/microtivity-IL...tronics+violet
Here's 100 for $7.77: http://www.amazon.com/microtivity-IL...tronics+violet These are loose parts, so you will have to solder them together. These are flat on top to give the wide angle. If you want a more narrow beam, you should get the rounded top style. They have lots of colors and styles to choose from. My wiring job:
Tags |
door pull lighting, footwell lighting |
Thread Tools | |
