Cold Air Inductions
Old 06-30-2013, 05:22 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Heads and cam
If you were to change your heads and cam, who would you go with? Looking around I came across AFR [always liked their stuff] Trick flow and TSP. I will be using this on the street 90% of the time and must run on 93. BTW car is a M6 and has 1-7/8 Kooks LT , off road pipes, flowmasters and ADM CAI. Thanks for any help.
Craig B is offline   Reply With Quote
Old 06-30-2013, 05:35 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
TO get your stock ones ported by AI, Brian Tooley, LPE. If money is no object I'd go with TFS or TSP smallbore heads and Lethal's enforcer cam have proven on Bplumcrazy's car!
I'd bump up compression to about 11.5 as well. It will be fine on 93.
Old 07-01-2013, 08:26 AM   #3
Jason 98 TA
Drives: Camaro
Craig give us a call and we can discuss your specific car and goals. We've got heads cam combos from $1500 basically! Not bad for potential to make 100hp gains!!
Jason 98 TA is offline   Reply With Quote
Old 07-01-2013, 12:04 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
TSP will be one of the companies I focus on when I do heads and cam.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-01-2013, 05:13 PM   #5
Craig B
Craig B's Avatar
Drives: 2013 1LE
Thanks for all the reply's. Weighing my options as of right now. Heads and Cam or Supercharger. Super charger is more $$ but easier to install and will make more power. With only 700 miles on the clock, I'm having a hard time tearing the engine apart.
Old 07-01-2013, 06:21 PM   #6
Craig B
Craig B's Avatar
Drives: 2013 1LE
From what I have read, the LS3 heads aren't all that bad. You can get more power from a cam change, over a head change.
Old 07-01-2013, 06:36 PM   #7
flyinglow57
Drives: rumble bee,2SS 6sp
I have cam only tsp 231/236 cam to be specific and love it. Never dyno'd but did 117 in the 1/4. So decent hp. If you do anything port the stock heads. I bepieve tsp does that as well. Great company to deal with. Got their full exhaust also. Never had a problem when ordering anything.
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
